It is currently Thu Apr 23, 2026 6:39 pm
Post Posted: Mon Jul 28, 2008 8:47 pm
Hi all
Probably been done before but meh... (flame suit on)
What's the best oil to run in my GV (V6).
Any suggestions?
What brand? Weight? etc
What do other people use? I've heard good things about Penrite...
It's done about 165,000k's
Pete
Sadly Zookless :(
Post Posted: Mon Jul 28, 2008 9:38 pm
flame suit..... mate, this isn't outers!
people actually help around here.
As for the oil, I dont know but someone will.
Post Posted: Mon Jul 28, 2008 10:21 pm
I am pretty sure you do some harm to your engine if you DONT use a 10W/30 oil, the lifters or timing chain tensioner play up
Motul do an oil in that weight, along with Castrol I think, but I like Motul :wink:
Post Posted: Mon Jul 28, 2008 10:34 pm
found castrol magnatec to work well on my gv
Post Posted: Mon Jul 28, 2008 10:47 pm
5W/30 by far the best.
Post Posted: Mon Jul 28, 2008 11:09 pm
:lol: Why do you think I asked here?...
10W/30is the go? Sound a freckle light to me. 20/40?
It does sound a bit 'tappetty' when warm I think.
(note: I could be wrong)
Pete
Sadly Zookless :(
Post Posted: Mon Jul 28, 2008 11:11 pm
listen to Bruce, if he says 5/30 its 5/30, I am only trying to remember what I saw in his shed :wink:
Post Posted: Mon Jul 28, 2008 11:35 pm
I have tried 10/30 and others and I can tell you from 4 years of driving a GV that 5/30 is way better than 10/30 by a country mile. Everything runs smooth and quiter from cold start to fully warmed up. Has to be good qualily Full synthetic oil like Castrol 5/30.
Post Posted: Mon Jul 28, 2008 11:37 pm
Your nuts Tim. Try 5/30 oil. I do however run Magnatic in my VRX Lancer from new. (9 years oils) and never had a prob but the mighty GV's like 5/30 oil JMO
Post Posted: Tue Jul 29, 2008 12:48 am
:rofl: well said
Post Posted: Tue Jul 29, 2008 1:06 pm
Yeah - 5/30 all the way....
I ran Magnatec for a while (have been running in my Z since I got it and never had a problem) but noticed the dreaded tensioner rattle getting more noticable, so thought I'd try some 5/30 - and it made a big difference!
Post Posted: Tue Jul 29, 2008 1:32 pm
Yes I used to run 10/30 and started to get the tensioner rattle but then changed to 5/30 and no more noise.
Post Posted: Tue Jul 29, 2008 1:59 pm
a wise old suzuki technician ( who worked on them since the lj ) said tou use oil flush for 30 minutes, drain, fill with magnatec or castrol sinthetic and put in a litre of moreys oil stabiliser, bugger me the old gut was right. what tensioner noise......
Post Posted: Tue Jul 29, 2008 2:33 pm
What is oil flush?
Post Posted: Tue Jul 29, 2008 3:34 pm
made by nulon. add it to your old oil, run the car for 30 min and it cleans up alot of carbon deposits.
Post Posted: Tue Jul 29, 2008 3:42 pm
It's a cleaning agent you add to the oil and run for a bit before dropping it out. Makes a big difference to some motors.
I have found with most late model stuff the lighter the oil you use the quieter (and better) they run. Using thicker oils to shut them up does not work. I won't use anything thicker than 10w40 in anything post 1990.
As a side note the newer Hondas run a 0w30 oil, almost like water.
Post Posted: Tue Jul 29, 2008 3:48 pm
:D i will have to try that
Post Posted: Wed Jul 30, 2008 5:38 pm
I just got off the blower to the local suzuki dealer and he said they run 10/30W. I asked about 5/30W and he said it wasn't necessary and that 10/30 would be fine. My owners manual also 10/30.
Confused as I am, I'll go with the consensus of the gurus on here and get 5/30W.
I'll check out different brands of oil on they way home from work at supercrap. Leaning towards Magnatec I think.
Cheers for the advice people! 8)
Sadly Zookless :(
Post Posted: Wed Jul 30, 2008 9:07 pm
10W30 semi synth is fine. I've run it in the past few oil changes but am now using 5W30 fully synth only because Supercrap were on special. It was the same price as 10W30 semi synth.
I can't tell any difference between the 5W30 and 10W30 and there's no timing chain rattle with either.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Jul 31, 2008 12:39 am
Bastard castrol only sells oil in 5l containers and I need 5.5 for oil and filter. :x
Would it be bad form to go to a local mechanic and see if they sell bulk oil?
Ok I'm a tightarse, but why spend more than I need?
Sadly Zookless :(
Post Posted: Thu Jul 31, 2008 1:35 am
Cause next time you only need to buy 1 :-)
Post Posted: Fri Aug 01, 2008 10:25 pm
Job done this arvo 8).
No issues, oil filter is a bit of a bastard though (for someone with limited skills like me).
Runs a lot quieter too!
Thanks for the advice all!
...now for some friday drinks! :cheers:
Sadly Zookless :(
Post Posted: Sat Aug 02, 2008 12:42 am
no worries mate. I found the best way to get filter off was through the wheel arch area. :-)
Users browsing this forum: No registered users and 299 guests
