It is currently Mon Oct 19, 2026 5:59 am
Post Posted: Wed Oct 27, 2010 8:12 am
Hey guys, This is my first time so bare with me haha. What i'm wondering is has anyone else with a 99 Jimny with a g13bb had as much trouble with the front engine oil seal as i have??? today i replaced it for the 3rd time in 18 odd thousand ks..... I'm a mechanic so i do know the correct procedure but i just cant work it out??? 8O Its almost asif its building too much crank case pressure. the seal simply pops out then runs against the crank cam belt pulley throwing oil EVERYWHERE!!!!!!! anyone have an idea?
Post Posted: Wed Oct 27, 2010 8:13 am
Blocked crankcase breather???
Post Posted: Wed Oct 27, 2010 8:15 am
checked that buddy. all good....
Post Posted: Wed Oct 27, 2010 8:20 am
how hard is the seal to get in ?
Post Posted: Wed Oct 27, 2010 8:24 am
well thats the thing... not very. a good push does it. but i have been putting it in with lock tight and also have tried 515... still no good. the cam pulley seems to be worn where the seal pops out and runs on it... that would tell me why it can come out so far but doesnt explain why its moving in the first place
Post Posted: Wed Oct 27, 2010 8:28 am
hows the keyway on the crank , ive seen the keyways flog out and the sprocket rocks back and forth and wears , then the sprocket rubs on the seal and causes the seal to wear the oil pump housing where the seal goes in ..
Post Posted: Wed Oct 27, 2010 8:33 am
the woodruff key on the crank itself it tight as. but i did notice that the cam belt pulley was a lil loose on the crank. i can pull it on and off by hand and can wriggle it just a bit back and forth.
Post Posted: Wed Oct 27, 2010 8:39 am
the seal itself , should be a fairly tight tap in fit in the housing , if it isnt , you either dont have the correct seal , or the housing is worn , i know you are a mechanic , but how are you checking the pcv ?
Post Posted: Wed Oct 27, 2010 8:56 am
well i pulled it out and i can blow through the pcv without even trying from the end that goes into the rocker cover,but from the manifold side i cant blow through at all. in regards to the seal im sure its the right one... i keep thinking it should be a tight fit, but not having touched a g13 befor this one, i just dont know any better.
Post Posted: Wed Oct 27, 2010 9:25 am
pull it out of the rocker cover and leave it attached to the hose to manifold , start the car and put your finger on the pcv , does it pull vacuum ?
Post Posted: Wed Oct 27, 2010 10:59 am
i had to have the front crank seal done on mine the other week (i got an m13a tho) and my mechanic said the seal he put in was a lot diff to the old one it was metal and rubber not completely rubber. maybe check if you can get another type of seal for it. are you using genuine of am?
Post Posted: Wed Oct 27, 2010 7:14 pm
righto losfer ill check that this morning. ive been using aftermarket seals but they are all rubber. ive been looking for a steel backed seal but havent been able to get my hands on one..... guess ill have to try harder haha.
Post Posted: Wed Oct 27, 2010 7:18 pm
just checked. and yes it is pulling vacuum
Post Posted: Sat Mar 26, 2011 2:27 am
did you ever find out was causing the seal to flog out?
i had mine done again after my last post (just before xmas last year) and it just noticed this morning that its started leaking again :( its giving me the shits! my mechanic checked the pcv valve and did a comp test and he said it was all ok. maybe it just needs a speedy sleeve on it or something.
if i wasn't trying to save for my holiday i would seriously consider making a big block jimny :) hahaha.
Post Posted: Sat Mar 26, 2011 2:33 am
genuine seal?
Post Posted: Sat Mar 26, 2011 2:58 am
Had to do my Mrs's Jimny Front main Twice, 1st time just replaced it hoping it would sought it out. 2 weeks later, same deal
was suggested to me to wack a speedy sleeve on there, hasn't leaked since. it was leaking because the Crank was worn where the FMS sits on it. just provided a decent surface for the seal to sit on.
haven't had anymore trouble's myself.
hope this helps :)
Stocker
Post Posted: Sat Mar 26, 2011 4:34 am
yea thats wat i was thinking needs a speedy sleeve.
Post Posted: Sat Mar 26, 2011 5:37 am
genuine seal?
Sound's like that may be the go.. :D
& if the crank's not worn, a new cam belt pulley (off the crank)
Post Posted: Sat Mar 26, 2011 2:02 pm
when we had the g13 in our, over 3 yrs we did 3 seals, it may be a common problem,
have just done our first on the g16 so see how it goes hopefully its not as common and on the g13
dodgy brothers mechanical
Post Posted: Mon Mar 28, 2011 8:14 am
Only use genuine seals.
We use to use non gen seals but had about a 90% failure rate so its genuine all the way now days and no problems anymore.
Suzuki is my way of life.
Post Posted: Mon Mar 28, 2011 8:17 am
SPEEEDYSLEEVE's People!!!!!! i have Never ever ever ever ever had one leak again after i put one on :)
Machined surface FTW :)
Stocker
Vehicle: 1999 Jimny with to much!
Post Posted: Wed Nov 28, 2012 9:17 pm
Does anyone know the speedy sleeve part number for G13BB engine crank shaft?
Vehicle: Suzuki Jimny 1998
Post Posted: Thu Oct 10, 2019 11:05 pm
Hi, I know this is old AF but...
or it's diameter?
thanks
Users browsing this forum: Google [Bot] and 413 guests
