| Author |
Message |
Verm1n
Joined: Tue Oct 28, 2008 10:30 pm Posts: 1395 Location: Ipswich
 Posted: Tue Mar 29, 2011 1:12 pm |
as title says..
inlets/outlets are on the passenger side.. the 1ltr sierra ones have it on the drivers side..
Brad ipswich area
Fity
Joined: Sun Nov 07, 2010 11:58 pm Posts: 148 Location: Sydney
Vehicle: Suzuki LJ50 & LJ81
 Posted: Tue Mar 29, 2011 10:00 pm |
I got one from a LJ50 120y conversion if that fits.
Verm1n
 Posted: Tue Mar 29, 2011 10:09 pm |
 my 81 has the 120y conversion and the radiator is buggered
how much u chasing for it?? post to bris??
Brad
Fity
 Posted: Tue Mar 29, 2011 10:19 pm |
It's been a while since I looked at it and I can't remember if it was great or crap. I will dig it out and let you know.
Verm1n
 Posted: Tue Mar 29, 2011 11:50 pm |
cheers mate, i doubt it could be worse than mine :S
tanshi
 Posted: Tue Mar 29, 2011 11:59 pm |
I just had a sierra rad modded, to have both inlets on the other side.
I have it triple cored too and it was $300. if your just swapping inlets it wouldnt cost much.
Verm1n
 Posted: Wed Mar 30, 2011 12:50 am |
true.. i got a dato 1 but the core is f@#$'d
might even look at a bigger radiator yet..
cheers though.. p.m the place where u got it done tanshi
tanshi
 Posted: Wed Mar 30, 2011 12:56 am |
a 2 litre vit one has the inlets on the right side. you might have a hard time fitting it, baleno also
its a place down near the cemitary, not 100% what its called
Verm1n
 Posted: Wed Mar 30, 2011 1:20 am |
cheers for thats
Highway-Star
Joined: Thu Apr 30, 2009 11:30 pm Posts: 4109 Location: Ipswich
 Posted: Wed Mar 30, 2011 4:05 am |
tanshi wrote: its a place down near the cemitary, not 100% what its called
Ipswich Radiator Works
_________________ Clearance Hole Technology
Verm1n
 Posted: Fri May 27, 2011 5:38 am |
Fity wrote: I got one from a LJ50 120y conversion if that fits.
did u find thats radiator FITY??
Brad
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Fri May 27, 2011 1:16 pm |
I have a custom triple core radiator that came out of an LJ with a Datsun engine, it as outlets on passenger side, thermo fan fitted and the bottom tank is even modified and cut out to clear a Sierra steering box in an LJ should you decide to go that way at some time in the future. $50
Brad I will get it out of the shed and take pic tommorrow
Verm1n
 Posted: Fri May 27, 2011 11:22 pm |
2stroker wrote: I have a custom triple core radiator that came out of an LJ with a Datsun engine, it as outlets on passenger side, thermo fan fitted and the bottom tank is even modified and cut out to clear a Sierra steering box in an LJ should you decide to go that way at some time in the future. $50
cheers heaps for that
im heading to norman park this avo to check out a car for a friend.. soo might swing by if u p.m an address
Mob is 0419661732
Brad
