It is currently Thu Nov 05, 2026 11:27 pm
Post Posted: Thu Mar 31, 2011 10:53 am
*'99 Jimny Auto*
It seeme that the front LH auto hub wants to self engage.. On deceleration fron 40ks you can hear it grating, at 5ks it seems to grab in, or out?
There is no indication light coming on
Just seems to be at times of high vacuum, ie coasting to a stop.
Are the hubs spring return? could it be a broken spring?
Possible leaking vac switch/valve?
There is no noise or probs in 4WD.....
This is the 'stick shift' 4WD NOT Electronic............
Your inputs appreciated...........Bill :(
Post Posted: Thu Mar 31, 2011 11:03 am
Not sure what is causing that, but ditch them and get manual locking hubs. JMO
Post Posted: Thu Mar 31, 2011 11:08 am
I had thoughts along that line, but if I could I would rather keep the auto's
as I have found them very handy, no muddy boots !!
Post Posted: Thu Mar 31, 2011 11:35 am
That's why i like mine, but once they pack up i will swap over to manual locking hubs, to save the hassle of fixings the auto ones.
Post Posted: Fri Apr 01, 2011 6:50 am
Bump up,,,, now rhat we are on air !!!!!!!
*JIMNY*
'99 G13BB, Auto, White.
Post Posted: Fri Apr 01, 2011 8:54 am
Restart...............................
*JIMNY*
Vehicle: WR250F/Jeep XJ
Post Posted: Fri Apr 01, 2011 8:59 am
Didn't ZookyLiz Have a similar issue a few weeks back?
ahhh...search brings the goods
http://www.auszookers.com/index.php?nam ... light=hubs
LIKE US ON FACEBOOK - KPD4x4
Post Posted: Fri Apr 01, 2011 7:08 pm
Thanks Dank, on from there I found a great big jimny site with all the details on the auto hub setup and operations, They are a bit complex..
thoughts now are towards manual hubs !!!! But would still rather the auto's... muddy boots reason !!!
Any more help would be appreciated from all
Regards to all Bill
*JIMNY*
Post Posted: Fri Apr 01, 2011 7:13 pm
first step in problem solving has to be pull the vacuum lines off and plug them and drive around for a while, if it stops then start looking for where the vacuum gets through, if it doesnt it in the hub somewhere.
Dont discount it being the brakes either
Post Posted: Sat Apr 02, 2011 12:00 am
Regards to all Bill
thats exactly why i put manual hubs on mine, i couldn't be bothered mucking around to fix the auto hubs when i knew they would fail again. fitting manual hubs is piss easy, takes about 10mins once you have the spacers.
only down side to manual hubs is when you go off-road then forget to take the hubs out then go up the beach a week later and then "put the hubs in" and nearly get bogged casue of 2wd! hahahhahahaha
Post Posted: Sat Apr 02, 2011 12:27 am
About 30mins ago I did the exact same thing. Went down this track licked my hubs in then went for a "recon play". Then I was stuck with one wheel in some mud not going anywhere front wheel in my side wasnt moving and I thought the other side may have been spinning. Got out and saw they were on "FREE". So I smacked my forehead and drove on without an issue.
Post Posted: Sat Apr 02, 2011 1:45 am
after the beach trip i painted a silver mark on mine so now i can see quickly when they are locked or free.
Post Posted: Sat Apr 02, 2011 4:58 am
Many thanks.... Now I am looking for the manual hubs to suit...
Any around? PM me. $ ?.
Oh and the spacers as well...
AND some silver paint!!!!
Bill
*JIMNY*
Post Posted: Sat Apr 02, 2011 4:59 am
I do believe big jimny sell them
Post Posted: Sat Apr 02, 2011 6:21 am
go to the wreckers and get some sierra hubs the will fit.
then go to a machine shop and ask them to turn up some 10mm thick rings on the lathe using the od of the sierra hubs and the id as just inside the small lip on the inside of the hubs. shouldn't be to expensive i don't remember how much mine were but it wasn't to much.
Post Posted: Sat Apr 02, 2011 10:12 am
you could go super lazy and fit drive flanges from a vitara. Constantly locked front means it will be spinning all the time....but it solves the muddy boots issue!
Post Posted: Sat Apr 02, 2011 10:14 am
Weld the hubs locked!!
Post Posted: Sat Apr 02, 2011 10:54 am
Actually welding, or fitting a packing block might not be such a bad idea,,,, at least till I can find a set of manual hubs......................
*JIMNY*
Post Posted: Sat Apr 02, 2011 11:09 am
If you don't like your transfer...
Post Posted: Sat Apr 02, 2011 11:23 am
Front disconnect...even lazier :D
Post Posted: Sat Apr 02, 2011 8:35 pm
If I was happy with 2WD, YES..... I use our New SX4 for 2WD WORK,,,,,,
OK back to looking for the manuals ....
Any around??? (cheap)
I see new ones around but are a bit pricey........... :steamroller:
Post Posted: Sun Apr 03, 2011 7:12 am
THANK YOU ALL .....\
I got onto a set of manuals from Zook95 's wrecking project....
Bill
*JIMNY*
Users browsing this forum: Google [Bot] and 145 guests
