It is currently Thu Nov 05, 2026 7:32 pm
Post Posted: Thu Mar 31, 2011 7:28 pm
Are spring clamps needed for a 95 LWB, or can you get them out without clamps?
Regards,
Ranga
Post Posted: Thu Mar 31, 2011 9:12 pm
When I put spacers in the swb vit I simply tied the springs up under compression of the car, used some wire, so no stretch.
Was piece of cake, I assume there would be no diff with a LWB.
Post Posted: Thu Mar 31, 2011 10:52 pm
Well, the back ones were easy, but I'll definitely need clamps for the front :( Now I just have to find pair!
Regards,
Ranga
Post Posted: Fri Apr 01, 2011 8:46 am
i compress the spring and tied them up with tie down straps bit rough but it got me by when i had to get the springs in with a 30mm spacer. i did treat them like a loaded gun.
Post Posted: Fri Apr 01, 2011 8:48 am
I just drop top of strut, and spring all falls out.
A bit tighter now with 50mm spacers, but still easy.
Post Posted: Fri Apr 01, 2011 8:51 am
Can help to unclip brake hose from strut, too
Post Posted: Fri Apr 01, 2011 12:15 pm
+1. It's also easy to drop the swaybar and you shit them in.
Post Posted: Fri Apr 01, 2011 2:11 pm
Try each step, if still not enough room go to next one:
Undo strut (top or bottom)
Release brake line clips (on strut and/or chassis)
Undo swaybar end
Undo steering tie-rod end
Undo lower balljoint (support hub first!)
By now the control arm should be hanging vertical, so if you still can't get the spring in you're doing something seriously wrong...
Post Posted: Fri Apr 01, 2011 6:41 pm
Ya not doing it correct if you think you need clamps for the front. :wink:
Post Posted: Fri Apr 01, 2011 7:02 pm
While that work's, I feel it's my civic duty to point out, that that is FUCKING DANGEROUS!!!!!
I've seen the aftermath of floor mounted spring compressor's let go, a mate had his skull reconstructed as a result....
& what Bruce said........ :wink:
Loosen of your control arm bush bolt's, stick the spring in & use a trolley jack to jack up the control arm (not off the ball joint) up into place, please use a lil caution while doing this, spring's can go flying..
Post Posted: Fri Apr 01, 2011 8:37 pm
sway bar?
Oh yeah I remember them :))
Never done it with a sway bar on, but yes it would need undoing.
Post Posted: Fri Apr 01, 2011 9:04 pm
with the sway bar , brakes, strut and axle removed my lower arm doesnt drop low enough to let the spring fall out. There is always some tension on the spring. It also touches the bumpstop inside the coil when trying to put coil in / out. But mine is a GV.
Might have to spend a day at Chrisovers place comparing the differences between the GV and Vit front setups.
Does anyone have an old Vitara lower arm i can borrow / steal to check the differences?
Post Posted: Sat Apr 02, 2011 6:09 am
Yes, but it's in Brisbane...
Post Posted: Sat Apr 02, 2011 6:23 am
On a gv the rack ends dont allow it to drop enough, best to pull the hub off at the bottom balljoint
If we could get the god damn massive springs Bruce got made up without compressors then anything is possible :)
Post Posted: Sun Apr 03, 2011 8:04 pm
i had a lot of trouble getting the control arm back into position doing it this way. i think the only way the springs would just drop i out when you undo the strut would be if you had some diff drop brackets. i also remember royce saying that he liked to undo the circlip on the stub axle to relieve pressure off cvs.
Post Posted: Sun Apr 03, 2011 9:23 pm
Yes remove the clip for the cv. The cv will slide out allowing the arm to drop. A few weeks ago I (and 2 others) did a lift on a GV. Rear's took about 15min a side with the front taking about 45mins a side.
Users browsing this forum: No registered users and 204 guests
