It is currently Thu Nov 12, 2026 10:08 am
Post Posted: Wed Apr 20, 2011 11:20 pm
Hey guys, just wondering what is needed if I'm putting a vitara 98 engine into a 94 sierra? Do I need the vitara gear box as well?
And the same question, just ruth a corolla engine, I know that I'd need the box, do o need anything else?
Post Posted: Wed Apr 20, 2011 11:29 pm
Some will say the 1.6l gearbox, some will say the 1.3l is fine.
BenT sells what you need, never used any of his gear personally, rav reviews but.
Post Posted: Wed Apr 20, 2011 11:33 pm
you can use the sierra box. it will wear more quickly however.
BenTs kits are great
Post Posted: Thu Apr 21, 2011 12:55 am
Is anything else needed when putting a vitara engine into a sierra? loom etc?
Every problem can be solved with a Ratchet.
Post Posted: Thu Apr 21, 2011 1:00 am
what is a vitara 1.6 front cut worth?
Post Posted: Thu Apr 21, 2011 1:05 am
I had a search for you, I suck at it tho, so cannot find what I was after, but there are a few write ups here on conversions.
There is an involved write up in the teck section, very well done, its a different motor to what you are considering, but it will give you some ideas.
http://auszookers.com/index.php?name=News Its the first one.
Post Posted: Thu Apr 21, 2011 1:06 am
Priceless. :lol:
Getting hard to find these days, so the jap import ones are pushing up towards $1800-$2K. :cry: 2yrs ago I could buy as many as I wanted for $1200 per front cut. :cry:
Post Posted: Thu Apr 21, 2011 1:20 am
could you make an rb30 fit into a sierra?
Post Posted: Thu Apr 21, 2011 1:23 am
anything could be made to fit if you want to put enough work in
Vehicle: Work van
Post Posted: Thu Apr 21, 2011 1:26 am
:helloo: http://www.auszookers.com/index.php?nam ... pic&t=4853
Vitara g16b step by step install :D
Swb softie spoa cromo front -50 beadlocks 6.5s :D
Post Posted: Thu Apr 21, 2011 1:34 am
I suck at searching, thats the one I was looking for, thanks.
Post Posted: Thu Apr 21, 2011 1:38 am
why not a cross flow 250. :wink:
Post Posted: Thu Apr 21, 2011 1:57 am
do you guys know how much work it'd be to swap an RB30 in compared to swapping in a vitara 1.6? much harder?
Post Posted: Thu Apr 21, 2011 2:02 am
heaps harder.!!!!!
Post Posted: Thu Apr 21, 2011 2:15 am
seen how long a RB30 is.....
Post Posted: Thu Apr 21, 2011 2:38 am
I'd be looking at an RB20DET before an RB30. Still the same physical size issues, but more power and less capacity.
Rear mounted radiator will be your only option though.....
Post Posted: Thu Apr 21, 2011 3:12 am
it's just that i have a vl sitting here with a perfect motor and box, it'd be epic to use that engine!
Post Posted: Thu Apr 21, 2011 3:32 am
Get a tape measure and size up the RB and box. Then see how it would fit the sierra. My guess is not well at all.
Post Posted: Thu Apr 21, 2011 3:40 am
ok sure, will measure it when i get home from work :S
Post Posted: Thu Apr 21, 2011 4:20 am
How long is a standard 1.3 engine and box?
Post Posted: Thu Apr 21, 2011 7:46 am
why not an SR20
Users browsing this forum: Google [Bot] and 81 guests
