It is currently Sat Aug 01, 2026 11:37 am
Post Posted: Thu Apr 21, 2011 2:53 am
Hi guys,
My lift is on order, so it's time to start thinking about tyres. The tyres will be used for Offroad use only so I'm not worried about wear. I'm looking into the simex centipedes at the moment.
Has anyone got these? How would people rate them? What other tyres are people running?
Matty
Post Posted: Thu Apr 21, 2011 2:54 am
all Depends what u want to do with them ? ...
ATM im running Maxxis Bighorns and love them to bits great on anything :)
Post Posted: Thu Apr 21, 2011 2:57 am
great in mud,
not much chop for any thing else. Just my opinion but there are much better tyres out there.
I have bfg km2's and love them
bighorns are a AT tyre in comparison to the centerpieds
Post Posted: Thu Apr 21, 2011 2:58 am
thats why i asked what hes planing on driving :)
Post Posted: Thu Apr 21, 2011 3:29 am
tanshi wrote:
great in mud,
what he said.
simex are fantastic in the slop. they suck on side-slopes and rocks.
to get the most out of them under a zuk you'd need to run beadlocks to be able to safely let enough air out of them to work properly (theyre very stiff).
i also found the beads very prone to get dirt/gravel/sand in them and create a slow leak. fixed that by putting tubes in.
Post Posted: Thu Apr 21, 2011 3:30 am
Matt I think you will find the Simex suit Vic conditions quite well.
Run them on narrow rims and let the pressure down quite low and they should be fine.
KM2's would be packed full of mud in 2 seconds in VIC. Shitty place to wheel if you ask me :P :lol: :thefinger:
Post Posted: Thu Apr 21, 2011 3:49 am
i ran mine on 15x7s and still couldnt go lower than 6psi without it looking like it was about to break the bead. i tested them in the driveway and they didnt properly bag out until around 2-3psi, then suddenly at like 1.5psi the sidewall just slumps and the rim touches the ground.
even in realllly loose mud i found the ass end slid sideways alot on a cross-slope, i even had a few brown moments where the whole car slid sideways across the slope i was driving before landing in a rut.
just something to be aware of, once i knew how they behaved i'd drive the side slopes diagonally or under more power to try stop it sliding away on me.
Vehicle: 95 Sierra Soft top
Post Posted: Thu Apr 21, 2011 3:51 am
Victoria, the place to be :) FOR MUD FUN WOW, thats the shit,
I was thinking baja claws bit on the $$$ side but again good for us down south
Post Posted: Thu Apr 21, 2011 4:18 am
swampers ftw. hell i even have some i would sell since i have found my new tires!
Post Posted: Thu Apr 21, 2011 7:07 am
Your question is "Are simex centipedes good"
My answer is YES. I love them for my Comp Sierra.
Vehicle: 75 Cruiser
Post Posted: Thu Apr 21, 2011 8:15 am
I have them also, have had two different sets different sizes, 31s and 32s, they measure 1 size bigger than they say.
I've found them to be pretty good, it's a very hard rubber so last forever. I only use them on dry rocks and dirt and they work pretty well. They suck on wet rocks, but i'd guess there's not many tyres that are good on wet rocks.
They're a pretty loose fit on the rims so tend to pop off or break the bead a bit if you let them down to 0.
Post Posted: Thu Apr 21, 2011 8:24 am
simex centipedes are pretty much the perfect tyre for victorian winter mud.
they will go through the real goop better than swampers.
their down side is muddy rock and there are better tyres in the dry.
but they are pretty hard to go past really in vic
Post Posted: Thu Apr 21, 2011 8:43 am
simex are a great tire, not much good in the sand but couldn really fault them any where else, such a robust tire
dodgy brothers mechanical
Post Posted: Thu Apr 21, 2011 9:14 am
Thanks for all the responses.
So basically the positives for the Simex's are:
Strong
Longevity
Good mud tyre
Negatives:
Poor traction on wet rocks
Poor traction going sideways along hills
Why do you guys run your tyre pressures so low? I crossed the Simpson in a GU Patrol on BFG AT's at 20psi and had no problems.
I did see the Swampers, and the Micky Thompsons. Whats a tyre that has good across hill grip?
Thanks
Matty
X2 My 32's served me well
www.youtube.com/watch?v=tfNWs4YicBA
Vehicle: 2018 DMAX
Post Posted: Thu Apr 21, 2011 9:25 am
Strong
Longevity
Good mud tyre
Negatives:
Thanks
Matty
23PSI is my road pressure... Gotta remember there isnt much weight on them
Vehicle: 75 Cruiser
Post Posted: Thu Apr 21, 2011 9:27 am
Because they are a hard tyre, you have to run very low pressure to get them to bag out. I usually run between 5 and 0 psi.
(This is offroad ONLY)
I find my tyres have good grip sideways on hills. If it's dry.
Post Posted: Thu Apr 21, 2011 9:28 am
u have to let tires on a suzuki low so they can bulge, expecially if its a mud terrain or a light truck tire,
i used to run my baja claws at 6 in the sand and around 12 on the rock, i found them great all round tires,
my troopie has 20psi and my sierra has 7 psi in the tyres.
my troopie weighs around 2500 kg and the sierra is around 900kg
Post Posted: Thu Apr 21, 2011 9:37 am
Makes sense, now I see its a weight thing, so I obviously need to buy beadlocks then, how much are they? Where can i source them?
Vehicle: 75 Cruiser
Post Posted: Thu Apr 21, 2011 9:43 am
I guess we forgot to ask,
What kind of driving do you do?
Do you need these tyres?
Do you have diff locks?
There's no point getting crazy stuff if you don't need it.
Post Posted: Thu Apr 21, 2011 9:53 am
I do all kinds of driving. I try to avoid rocks as much as possible, but I like playing in the mud a lot. I want to do a few long trips in it, but I will buy AT's for that. I don't have diff locks but I am planning on getting them after a few other things have gone in first. Il ike having crazy stuff lol.
Post Posted: Thu Apr 21, 2011 10:48 am
another virtually identical but cheaper option to simex is the silverstone exteames. they run a little small size wise though, but are quite a bit cheaper
Post Posted: Thu Apr 21, 2011 12:34 pm
See is you can get some second hand tyers and see if you like them.
Ive used 32 Simex on my Zook in Vic in many different conditions and I find them great, but Ive seen KM2's working well on zooks so I will prob 35's in the next year or so.
Post Posted: Thu Apr 21, 2011 10:25 pm
Golly, why on earth would you want to avoid rock?
Anyway, speaking from experience in Victoria, the only real advantage centipedes have over most other tyres is on slick clay climbs without any ruts. That's the kind of track where it's hard to maintain directional control. In these conditions, I've seen centipedes hook up better than any other tyre. That's a product of their narrow overall width and high ground pressure.
You're not running lockers though, so you're not getting onto those kind of tracks in any case. This isn't dismissive, it just means you're putting the cart before the horse. you can have a 56" tractor tyre, but if it's not being driven it can't get help.
Most guys running 'pedes have gone from a 10.5 or 12.5 radial mud tyre like a BFG or MTR or similar. Compared to these, a simex is awesome offroad. compared to a swamper, a silverstone, or a Krawler, they're not outstanding (except for on that one kind of track)
It's a shame that simex's have such a rubbish compound and carcass. If these were better, they really would be excellent tyres, but for the money, excellent performance on one type of track, and only fair performance everywhere else, doesn't make them a very appealing tyre.
The Silverstones look to be every bit as good for less money, and they look like they might have a softer carcass too.
The problem with Vic isn't deep mud - that's just boring -it's horsepower and big tyres. It's the transition from a deeply rutted climb, to a slick climb, to rocks, so blacksoil, to tree roots and back to clay.... all in one track. The simex might own the slick climb but in the ruts, it's all about diameter and width, and on the rocks and tree roots it's all about the flexibility of the carcass.
Simex's were designed by Chris Hummer as a competition tyre, (Winch challenge) and that's where they work. High horsepower, high speed, heavy car, one shot. that's as far from the way we drive sierras as you can get.
Personally, I'd run some very aggressive 7.50 16's like these -
They're cheap, easy on the car easy to fit, nice and tall, and let you save money for the lockers and gears you're going to need to make any big tyre work.
Across the vic club, we have quite few sets of Mongrels and silverstones at the 31-32" sizing, and swampers and Krawlers once we go above 32" but we also have a few guys running 7.50's too.
Oh, and http://vic.suzuki4wd.com/forum/index.php
Post Posted: Thu Apr 21, 2011 11:17 pm
The carcass on mine seem to flex well enough.
Post Posted: Thu Apr 21, 2011 11:35 pm
I don't believe that's a functional pressure you've posted there Red89 (i.e you'd drive the car like that). Note how the inner bead is coming away from the rim at the fold. That's going to fall off if driven far.
There's a big difference between posting a photo of a car with a flat tyre and the dynamic flexibility of a carcass when being driven on. I can't comment for everywhere, but we often combine very low tyre pressure with plenty of wheelspeed and bumping roots and rocks in ruts. Simex's fall off rims under these circumstances, and it's due to the rigidity of the carcass, which won't let the tread move far without loading up the bead.
Post Posted: Thu Apr 21, 2011 11:50 pm
there built with a hard carcass, simply for added strength and durability,
oh and chris designed the centipede for the malaysion rainforest challenge
Users browsing this forum: Google [Bot] and 226 guests
