| Author |
Message |
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Sat Apr 23, 2011 12:26 am |
My wt sierra has gone through 2 front diffs and 3 rears in the space of 6 months or around 7500km's. Only one hard offroad trip, mostly highway kilometres. What would be causing this? The first for both were the originals, I then swapped to 3.9 NT diff's from SCSW. These only lasted a few months and then they had gone from perfect to pretty much destroyed, heaps of play in the diff, terrible wining noises. I got the original WT diff rebuilt and then put it back in and within no time it was doing the same.
All wheel bearings have been replaced in the last 10000km's. All uni's have been replaced in the last 5000km. I'm only running 2" suspension, 2" body and 235/75R15's. Would bent housings cause this? Really sick of changing diffs so any help would be great.
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Sat Apr 23, 2011 1:08 am |
bent diff maybe, but thats would be destroying the side gears, not ring and pinions.... the oil in the axle might contain fragments of steel from the last diff, if i was you, i would take the 3.9 center to a diff shop, get them to work out whats wrong, then fix what they recommend, then hose out your axle housing with fuel, then redo your wheel bearings that way you have covered all bases
your not rough, so i doubt it would be a putting together error...
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Sat Apr 23, 2011 1:34 am |
look at things that haven't been replaced, my money would be on the housings.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Zook_Fan
 Posted: Sat Apr 23, 2011 1:55 am |
31zook wrote: bent diff maybe, but thats would be destroying the side gears, not ring and pinions.... the oil in the axle might contain fragments of steel from the last diff, if i was you, i would take the 3.9 center to a diff shop, get them to work out whats wrong, then fix what they recommend, then hose out your axle housing with fuel, then redo your wheel bearings that way you have covered all bases  your not rough, so i doubt it would be a putting together error...
Yeah every time i change a diff the whole housing was washed with fuel through high pressure spray. There was absolutely no metal left in the housing. The ring and pinion's don't seem to have any excessive wear or anything like that, it just seems to be getting out of spec enough that it is wining and the pinion bearing is failing. I will put up some photo's to see if there is something I am missing.
Yeah shep that is what I was thinking to but just wanted to see if it could be something earlier in the drivetrain causing problems, perhaps a transfer fault or something? Its got me
billrogers
Joined: Mon Aug 16, 2010 11:03 pm Posts: 81 Location: Dubbo 2830 NSW
 Posted: Sat Apr 23, 2011 2:17 am |
How much do you use 4WD? Not permanantly in 4WD?
_________________ *JIMNY*
'99 G13BB, Auto, White.
31zook
 Posted: Sat Apr 23, 2011 2:25 am |
The tcase couldn't be doing anything, i guess you should just check how your driving style is or the housing.
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Sat Apr 23, 2011 3:55 am |
Are you using mismatched R&Ps?
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Sat Apr 23, 2011 5:26 am |
Could it be the wrong oil or something?
Or not enough/no oil?
Not saying you'd forget, but sometimes we do silly things you know.
As for shep being on the money though, that's what I'm thinking too, although how could you get the axles in properly, wouldn't everything not fit properly and not want to turn?
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Sat Apr 23, 2011 6:04 am |
Haven't been doing jumps have ya ZookFan????
11_evl
Joined: Tue Apr 10, 2007 11:30 pm Posts: 846 Location: logan reserve, Brisb
 Posted: Sat Apr 23, 2011 7:43 am |
Using engine oil instead of diff oil does that fast.
Driving style, clutch dumps and compression skids can cause that
Hitting tailshaft on rocks can be a problem. Collaspable spacer crushed
_________________ 92 sierra, 40" treps, full hydro, F&R steer, 106"W
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Sat Apr 23, 2011 9:57 am |
Zook_Fan wrote: My wt sierra has gone through 2 front diffs and 3 rears in the space of 6 months or around 7500km's. Only one hard offroad trip, mostly highway kilometres. What would be causing this? The first for both were the originals, I then swapped to 3.9 NT diff's from SCSW. These only lasted a few months and then they had gone from perfect to pretty much destroyed, heaps of play in the diff, terrible wining noises. I got the original WT diff rebuilt and then put it back in and within no time it was doing the same.
What exactly is letting go inside the diff ctr? is it chewing bearings or snapping teeth or side gears?
_________________ B4T
daisy
Joined: Tue Dec 30, 2008 10:30 pm Posts: 285 Location: Redbank Plains, QLD
 Posted: Sat Apr 23, 2011 10:06 am |
Built4thrashing wrote: What exactly is letting go inside the diff ctr? is it chewing bearings or snapping teeth or side gears?
Very good question there.
chewing bearings or snapping side gears etc - bent housing or axles
snapping teeth - bad install - preload or backlash set wrong.
pinon - driveshaft related or wrong preload
when you rebuilt it... did you reuse the same spacer in the pinon???
as that couldve been the problem to start with as spacers are collapsible.
Zook_Fan
 Posted: Sat Apr 23, 2011 10:29 am |
billrogers wrote: How much do you use 4WD? Not permanantly in 4WD? Nope, front is disengaged as soon as i get on bitumen. Would have been barely time between the last front diff changed. 31zook wrote: The tcase couldn't be doing anything, i guess you should just check how your driving style is or the housing. I don't think it is driving style, I am fairly soft on it and i've only got a 1.3 at had so I don't think power could be to blame lump_a_charcoal wrote: Are you using mismatched R&Ps? Nope always matched pairs Teracis wrote: Oil stuff It has always had oil in it. Morey's stabiliser was added once the wining started in both instances. steve wrote: Haven't been doing jumps have ya ZookFan???? Yeah it has found air a couple of times.  Never intentional or very high, just high speed, low, flat jumps on a rally course. 11_evl wrote: Using engine oil instead of diff oil does that fast. Driving style, clutch dumps and compression skids can cause that Hitting tailshaft on rocks can be a problem. Collaspable spacer crushed Diff oil used. As above I don't think driving style is the problem, the second and third diff I changed my driving style in an effort to stop it happening again. Could have been rocks... Built4thrashing wrote: What exactly is letting go inside the diff ctr? is it chewing bearings or snapping teeth or side gears? Bearings. Teeth are fine. daisy wrote: Very good question there.
Side gears are fine, teeth are fine. When you say pinion do you mean teeth or pinion bearing? Pinion bearing was shot the first time but I believe that was uni related. New spacer when rebuilt.
So in summary I am thinking housings and or axles are to blame.
Built4thrashing
 Posted: Sat Apr 23, 2011 11:29 am |
Housing is bent. replace the housing and your problem will go away.
daisy
 Posted: Sat Apr 23, 2011 10:19 pm |
pull axles and diff centre out...
and pull those seals out as well.. have a look thru it from one end to another..
You can see if the tube is curved looking through it which will give you a better idea of how bad the housing is bent.
SSSIERA
Joined: Tue Mar 22, 2011 1:26 pm Posts: 1770 Location: Perth's RUF
 Posted: Mon Apr 25, 2011 11:54 am |
havent been playing in puddels have ya ????
_________________ THINKING BEFORE POSTING!!!
Zook_Fan
 Posted: Mon Apr 25, 2011 12:12 pm |
I will be replacing the housing. Definetly bracing the new one before it goes in though.
I have been driving through mud if that is what you mean but that is not the issue as the oil has always been clean when changed.
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Mon Apr 25, 2011 12:28 pm |
Zook_Fan wrote: I will be replacing the housing. Definetly bracing the new one before it goes in though. I have been driving through mud if that is what you mean but that is not the issue as the oil has always been clean when changed.
Before you brace the diff weld it to a piece of solid steel that wont twist or bend. Once you weld to the diff and allow it cool it will twist unless braced to stop it.
noob cad
_________________ Camels have nice toes
