It is currently Sat Aug 01, 2026 11:34 pm
Vehicle: 2001 Jimny M13A
Post Posted: Tue Apr 26, 2011 4:47 am
G'day
Found this while doing Alternator research on the internet.
Has anyone used, seen or know about these?
They are a "one wire" alt.
Exactly the same size (dimensions) as my 70A stock Alt in me Jimny. :wink:
The one that takes my fancy is PN 8148 (XS-Volt reg) as you can play around with voltages, which may be a good thing to get the charge right for AGM/Gell batteries.
Some more info can be found here
Post Posted: Tue Apr 26, 2011 5:04 am
http://www.auszookers.com/index.php?nam ... ic&t=14726 :wink:
Post Posted: Tue Apr 26, 2011 5:11 am
monkey wrote:
http://www.auszookers.com/index.php?name=Forums&file=viewtopic&t=14726 :wink:
Yep!! Looking into this one too :D
Post Posted: Tue Apr 26, 2011 5:21 am
That looks pretty well the same as the Denso unit I used, its also the same dimensions but it runs a 17mm shaft and is a bit deeper in the body, very happy with my swapover.
Post Posted: Tue Apr 26, 2011 5:34 am
Yep!! :D
Still looking at the mod you came up with, as it's a easy alt to get hold of,
simple but tight fit etc.
I'm like the above more because of what you can do with it - it being adjustable for different battery types etc
Users browsing this forum: No registered users and 1305 guests
