It is currently Fri Nov 06, 2026 3:32 pm
Post Posted: Thu Apr 28, 2011 5:20 am
i stripped down a sierra transfer to install 6.5s. i completely stripped down the case and gave it a good degreasing, because it was full of mud.
Im in the middle of putting the case back together and i cant get the shift rail back into the centre housing.
The steel ball sits ontop of a spring, i need to compress it to slide the shift rail back in, any ideas on how to do this, is there a special tool? :blink:
Post Posted: Thu Apr 28, 2011 5:38 am
Full instructions are on the lowrange website. Trail creeper also show them.
Vehicle: Daisy
Post Posted: Thu Apr 28, 2011 6:07 am
Want33s is spot on, didn't you get the instructions with your gears?
Also, the trick for doing that bit, is to put the shaft in from one side, a flat blade screwdriver in the other, depress the ball with the screwdriver and slide the shaft through at the same time (pushing the screwdriver out of the way using the shaft)
Post Posted: Thu Apr 28, 2011 6:51 am
insert the bolt a few thread turns before you do.. that way if it goes pear shaped the spring wont shoot the bearing up
Trogdor 2 97 Sierra --- sold
zookless atm
Post Posted: Thu Apr 28, 2011 7:22 am
Bingo!!!
Post Posted: Thu Apr 28, 2011 9:07 am
i did get the instructions, but i did not see anything about this. they only mentioned reinstalling the other ball for the high/low shifter.
thats a good idea, ill have another go tomorrow
cheers
Post Posted: Thu Apr 28, 2011 11:16 am
because they don't remove the selector fork, they just leave it in..... :crazy:
Vehicle: Daisy
Post Posted: Thu Apr 28, 2011 7:49 pm
Pretty sure mine fell out (read I pulled it out) because I was trying to move it or something and pulled it all the way out. Just used the same trick they use on the other one.
Users browsing this forum: Google [Bot] and 127 guests
