It is currently Fri Nov 06, 2026 2:05 pm
Post Posted: Fri Apr 29, 2011 3:14 am
need a set of forged pistons. its a 1.6 sohc efi vitara. perth w.a any ideas
Vehicle: Yamaha scooter, 50cc
Post Posted: Fri Apr 29, 2011 3:38 am
Why? I thought you only needed forged pistons for high performance, high output motors. Seems like unnecessary spending to me
Post Posted: Fri Apr 29, 2011 3:40 am
maybe he is looking at building a high out put motor?
Post Posted: Fri Apr 29, 2011 3:52 am
i am building a high output motor
Post Posted: Fri Apr 29, 2011 3:58 am
do some googling for stuff like Honda G16B, B16 Vitara etc, combos of suzuki and honda, there is a honda engine that uses some form of Vitara piston as a strong low compression alternative for them.
you can get them for G13b (GTI Engine)
Post Posted: Fri Apr 29, 2011 5:29 am
lol well crikey, amazing hehe.
Seems sort of normal, bloke wants specialty items, he ain't going stock hey.
Post Posted: Fri Apr 29, 2011 6:20 am
all good. found it thanks to percy on redlinegti. if anyone needs some its at KMS ENGINE DEVELOPMENTS HONDA PERFORMANCE. thanks everyone
Vehicle: '96 LWB trayback
Post Posted: Fri Apr 29, 2011 7:08 am
The honda bore/stroke is identical, but the gudgeon pin position is different.
So the listed compression ratio of a honda piston will not be what you achieve in your g16 engine.
Also, the pistons are hardly the weak point and far from the first thing you need to address in a high boost turbo engine. Look first to the conrod end cap bolts and conrods. They're thin as matchsticks.
Vehicle: MY2019 Jimny
Post Posted: Fri Apr 29, 2011 7:40 am
Woo, Marco with teh tech!
Post Posted: Fri Apr 29, 2011 7:56 am
Im Definitly interested if someone is going to build a G16B Turbo Motor. I have seen the Honda/Suzuki Combo engine in the Redline GTI Forums. but noones posted up a proper build in AUS
Stocker
Post Posted: Fri Apr 29, 2011 4:05 pm
chris mills performance can get you custom dimond forged pistons made if they already arnt
Post Posted: Fri Apr 29, 2011 9:43 pm
My understanding of it is that the Honda guys use the Vitara pistons as they are considered to be pretty good. They offer the correct lowered compression for the Honda motor.
The Honda pistons are not going to help you in a G16b.
You need custom forgies, there isnt anyone that has them on the shelf as far as i could find.
Be prepared to pay if you go the custom forgies...........depends on the boost you intend to run.
Im using machined standard pistons.
I have learned alot from reading oozuks buildup. I suggest you start there.
Users browsing this forum: Zookscooked and 56 guests
