It is currently Sat Aug 01, 2026 8:34 pm
Post Posted: Fri Apr 29, 2011 9:31 am
ladies and gents thanks again in advance for your help.
as u all know im useless and know nothing about my own car. but that aside is anyone on here running 30s on there sierra. i have lots of newbie questions
for starters im hoping to slap somthing like this one my car. in the 30 x 9.50R15, on sunraisers.
questions are
what sorta ofset will i need
will i have enough power to drive them with the stock 1.3 and stock gears.
do i need to do a guard chop if im going a 2 inch lift and two inch shackles.
any other things that i am gona have problems with that u can see would love it if ya told me
cheers
troy
(soz bout the dribble)
THINKING BEFORE POSTING!!!
Post Posted: Fri Apr 29, 2011 9:39 am
a 25mm front bump stop spacer and moving the front diff moved forward 20mm will clear the 30s, it'a all about comfort if you want to change anything else :D
I have a 2" lift and 31s. Had stock gearin was drivable just not fun to drive.
Only took a hammer to the guards to fit.
Post Posted: Fri Apr 29, 2011 9:54 am
30s should be a little bit better then i guess. im replacing the front bar with a custom one so the front wont be a problem. but moving the diff isnt an option for me.
Post Posted: Fri Apr 29, 2011 9:55 am
Why not?
Post Posted: Fri Apr 29, 2011 9:57 am
why not?
Post Posted: Fri Apr 29, 2011 10:16 am
Im only running 30's on my reasonable stock zuk. Have a look at my build thread for some inspiration if you haven't already.
http://www.auszookers.com/index.php?nam ... pic&t=4826
Lil Foot!
Post Posted: Fri Apr 29, 2011 10:40 am
my wt was running 29's on stock rims stock suspension when i got it no probs! i cant see an extra 12 mm being a problem
Post Posted: Fri Apr 29, 2011 11:47 am
I have 2" efs spring lift on last zook and didn't scrub with 30's.
My Maruti build, Click WWW
Post Posted: Fri Apr 29, 2011 12:06 pm
http://www.abcspareparts.com/
http://www.cityview
Post Posted: Fri Apr 29, 2011 12:12 pm
beerhound wrote:
that looks neat!!!
Post Posted: Fri Apr 29, 2011 12:24 pm
28.8's or 235/75 tyres fit with the only mods required being flattening of teh wheel well seems and cutting the front bumper outriggers off.
You'd be surprised just how much extra hassle 30's are to fit properly re: no rubbing on full articulation/steering etc
I cleared mine with a virtual lift, massaging the arch behind the headlight buckets and moving my front diff 10mm forward. Overall I only run 10mm bumpstop extensions in the front.
Dan
Lil Foot!
Post Posted: Fri Apr 29, 2011 1:04 pm
I have 31's with probably 50mm spring lift and 100mm center shackles. The I got my bb hamer out and beat the shap edges of the guards, if u cut them every 20mm with tin snips they form easier and inverted me rears and used Hilux 2wd shocks at the back and am waiting for a vs wagon rears to come up at a good price to wack in the front. All in all a bit of guard rub but that's the name of the game. Where they rub is smooth so it won't chop your tires up.
pin-to-win racing
slowly building up my new zook
Vehicle: Yamaha scooter, 50cc
I ran 31's with stock gearing for about 9mths on mine, and other than a bit of excessive clutch wear, never had any real mechanical issues. You will loose 5th gear and any effective low range tho, but this can be adjusted for with changes to driving style, ie I used to drive steep descents with my hand brake engaged
Post Posted: Thu May 05, 2011 1:46 pm
cant move the diff because it to hard. measuring and all that crap. and noing me ill stuffit up some how. but im guessing im gona be alright with a two inch lift, outriggers gone and some slight pannel beating. if not ill chcuk some shackles at it
Post Posted: Thu May 05, 2011 2:05 pm
65 mil EFS Springs are great
i can clear 31s with it ... but will scrub .. on flex 30s with 65 mil lift
should clear ..
Post Posted: Thu May 05, 2011 6:20 pm
I'm running 235/75R15's with 4.1 diffs and 1L transfer and low range is still way to high. 30's with std gearing wouldnt be good in low range.
Post Posted: Thu May 05, 2011 6:49 pm
Use a ruler, measure 20mm back on the perch and plate. Drill. Put back together.
Don't chuck longer shackles on without longer springs.
Post Posted: Fri May 06, 2011 5:55 am
I was in the same boat as you and asked a few questions last week.
With a 2" BL it should clear 30" without a problem or a 2" spring lift. The rims you need for 30" are 15x7 on a -13 offset
I really wanted 31's but after reading more and getting a few answers i'll be getting some 30s on a 15x7 -13 rim...there shouldn't be any scrubbing if you have a 2" lift (either body or spring)
If you decided to go 31" you will need 15x8 rims on a -23 offset but i personally wouldn't bother with 31" if its your daily...plus you'll need to get a hammer and do some panel beating
Post Posted: Fri May 06, 2011 5:59 am
Please explain how this will stop it scrubbing once the vehicle is flexed up and the axle touching the bumpstop..
Lil Foot!
Post Posted: Fri May 06, 2011 6:53 am
You can use a 15x7 rim. Most prefer it on a zook.
Why wouldn't you bother with 31s for a daily? I run 31s on a daily fine, I love them. With correct gearing you can run 35s as a daily.
Post Posted: Sun May 08, 2011 12:22 pm
very helpful thread guys cheers.
im also a noob to the sierra setups and quite new to 4x4 in general.
im running 235/75's on my hardtop sierra without any lift. and running sunnys assuming they are -13 but haventy checked. sit nicely on the guards. was thinking of going to 30's or 31's but was advised against it due to stock clearance and gear dramas.
Post Posted: Sun May 08, 2011 1:28 pm
i think the biggest thing here that hasnt been addressed is gearing... getting 30" tyres to fit is all fine and dandy, but driving with them on and offroad is going to kill clutches and smash parts faster than anything.
my advice is not to go to anything above 28" without seriously considering reduction gearing, whether through tcase or diffs or both, you'll end up with a far more capable, more driveable zuk if you get the gearing sorted.
for 30's i think 4.16 tcase gears, for 31's im using 5.14tcase gears (although i have a 1.6 EFI engine) - those running the 1.3 carby might want to go 6.5 tcase for 31s.
Post Posted: Sun May 08, 2011 2:08 pm
well step one for me is getting my engine sussed. step two is getting the susspension sussed and step three is getting my tyres (and gearing if possible). though if im gona be spending money on gears i may aswell go for somthing bigger than 30s. the again the diff is on its way out already. if i pull the gear box to do gears ill smash a heavy duty clutch in it anyway. so i may aswell get all that i can out of those two b4 i start spending money on em.
Post Posted: Sun May 08, 2011 2:39 pm
He asked for opinions and that was mine
What would you suggest he does?!
Post Posted: Sun May 08, 2011 2:42 pm
As i mentioned earlier...i would love to run 31's but you need to do some panel beating and if its a daily 30's would be better plus you won't need any garden edging to the guards from bunnings :P
Post Posted: Sun May 08, 2011 4:06 pm
bleh... the chain of modding a suzuki
need new suspension- cant get standard springs have to go for a lift
lift looks gay with small tyres
bigger tyres added
bigger tyres need lower gears.
low gears needs more power
efi 1.6 added
to much torque/ grips = blown diff
needs new diff may aswell get lockers
start to get excited car
car falls on roof
buys a landcruza :)
Post Posted: Sun May 08, 2011 6:42 pm
:no:
Post Posted: Sun May 08, 2011 10:44 pm
bigger tyres added
low gears needs more power - Nope, thats what gearing fixes
efi 1.6 added
to much torque/ grips = blown diff - Nope (Axles go first)
car falls on roof - only if you can't drive =)
buys a landcruza :) - Only if you're gay.
Post Posted: Sun May 08, 2011 11:32 pm
What I was trying to point out here is that a 2inch spring lift is a static 2 inch lift, hence the car will stand 2 inch higher. Yes when its standing it will clear the tires no problems but when you flex it up to the bumpstop the height will still be the same between the axle and guards even if you were to use stock springs. Make sense?
Bodylift will lift the car 2 inch once again but in this case once the axle is on the bumpstop the guards will be 2 inch higher that what they usually would be. So no scrubbing.
Lil Foot!
Users browsing this forum: No registered users and 521 guests
