It is currently Sat Aug 01, 2026 12:29 pm
Vehicle: Coil Sierra
Post Posted: Sun May 01, 2011 8:26 am
ive found heaps of brake problem threads but cant find the procedure for adjusting rear drums on a sierra. Its a coily but i presume its done the same way. maybe someone could write a tech page on it.
Post Posted: Sun May 01, 2011 8:29 am
release handbrake
pump brake pedal a few times
job done :)
if you have a low pedal you have a problem, either wear in the hole the adjuster works on in the shoe, worn shoes, oversize drums, seized adjusters etc.
they are self adjusting mate.
Vehicle: LWB Sierra & XL7
Post Posted: Sun May 01, 2011 8:35 am
I know with the vitara, they're self adjusting. At one stage I thought mine would need adjusting but I removed the drum and found I needed new shoes So perhaps remove the drum and inspect the shoes to see how much meat is on there.
Otherwise there is an adjusting nut on the back of the handbrake lever or underneath, It should only be retentioned is the cable is not tight enough.
And here's a Tech thread on how to replace shoes: http://www.auszookers.com/index.php?nam ... ic&t=19978
Vehicle: '96 LWB trayback
Post Posted: Sun May 01, 2011 8:41 am
Ditto that they're self adjusting. From memory the manual says something along the lines of "hold 8kg of pressure for 3 seconds, then repeat x3"?
* Pressure and duration are estimates only, refer to manual for correct specs.
Post Posted: Sun May 01, 2011 8:50 am
How about adjusting handbrake cable ?
Post Posted: Sun May 01, 2011 8:52 am
well during a muddy glasshouse run i got a soft pedal and no handbrake. I cleaned the mud out today and still no luck. I notice when i brake the rh drum clicks like wheel of fortune. When i had the drums off i worked the handbrake spring on the drum and there was not much movement with the shoes.
if your back brakes are working properly there is no need to adjust the handbrake cable for anything other than how many clicks it pulls up, it wont make it work any better, infact will make it worse
ive never adjusted mine
Post Posted: Sun May 01, 2011 8:57 am
the adjuster might be seized and jumping on those teeth?
Post Posted: Sun May 01, 2011 8:59 am
How do you adjust the clicks? Mine is all the way up and still doesn't work very well.
Had new brakes when I bought it. Pssssssh@ doubt it
also the handbrake cable holder on the diff has been hitting the panhard mount. The cable popped out the holder and lost its tension.
Post Posted: Sun May 01, 2011 9:03 am
yeah with mud you really need to at least once pull em apart and clean out the moving bits and put some never seize on em
Post Posted: Sun May 01, 2011 9:07 am
can i clean out the adjuster and cylinder incase they could of dried up with mud?
Post Posted: Sun May 01, 2011 9:24 am
yeah I would, youll see what bits need to be able to move freely
Post Posted: Sun May 08, 2011 10:26 am
solved!!! The rear panhard mount on the body has been making contact with the rh rear handbrake cable mount on the diff. It mashed the holder and the cable came off the diff. Inside the drum the front shoe was sitting out of its locator where the cylinder shaft meets the shoe, when pushing the brake pedal the front shoe in the rh rear drum didnt move. Also new shoes and an adjustment will help. Fixed two problems in one go, one being the brakes and two being the clunking noise from the loose handbrake cable.
Post Posted: Sun May 08, 2011 12:43 pm
release handbrake
job done :)
Yea auto adjuster works with what shoes?? All the bloody shoe's ive tried have wayyy to bigger slot where the auto adjuster slots into them. Thus the shoes have to move like 10mm before they even engage the auto adjuster mechanism.
Lil Foot!
Post Posted: Sun May 08, 2011 7:02 pm
Even with everything working as it should the auto adjusting system never gets it good. I always give it a couple more clicks manually to get a better pedal (I hate spongy brake pedals)
Post Posted: Sun May 08, 2011 11:35 pm
Correct!
Lil Foot!
Post Posted: Mon May 09, 2011 12:05 am
JrZook wrote:
release handbrake
job done :)
on non mud pluggers that get a decent amount of life from the shoes, weld the hole up and file it back to a gap that suits you :wink:
Post Posted: Mon May 09, 2011 12:29 am
JrZook wrote:
release handbrake
job done :)
Brilliant minds think alike :wink:
Lil Foot!
Users browsing this forum: Google [Bot] and 201 guests
