It is currently Fri Nov 06, 2026 3:43 pm
Post Posted: Sun May 01, 2011 11:29 pm
hey guys I'm trying to decide if I should get 31's or use my dad's spare 33 bighorns, not sure what size, but they are fat bastards. Looking at a coily zook with 2' susp lift. I'd be putting a body lift in too and doing the tfer case. what is offset..? Is it a camber or spacers or anything along those lines? I'd also need wheels (king wheels?)
Post Posted: Sun May 01, 2011 11:36 pm
I'd go 31's. Either on a 15x8 rim with a -23 through to -28.
Or as some guys on here like a 15x7 rim on an equivalent offset.
Post Posted: Sun May 01, 2011 11:38 pm
I like as big as possible, if you can 33s.
Offset refers to the wheels, and how far from the centerline they are, big wide tyres need big offset generally.
What are your plans for the Tcase
Post Posted: Sun May 01, 2011 11:39 pm
Just saw, your in Qld, if this is to be on the road, I don't think you can run 31s even.
Post Posted: Sun May 01, 2011 11:43 pm
You can run any size tire in qld it's just cop bait nd illegal
Post Posted: Mon May 02, 2011 12:55 am
I have 30's and they are illegal....I think technically a 29 is illegal :roll: I don't like your chances getting a coily front end holding up to 33's if you are going to wheel the shit out of it. The 1.3 might not be a big fan of pushing them around either
Post Posted: Mon May 02, 2011 1:05 am
Stay with 31's. Going up to 33's with make the job eleventybillionX harder - Gearing, axle strength, clearance all get much harder to resolve. 31's are sweet on a coiler with a 2" BL and a gear drive transfer with 4:1 gears.
Post Posted: Mon May 02, 2011 2:51 am
Oh ok, well i'm not planning on having it 'legal' because we're only allowed a diameter increase of 1.5cm before it becomes illegal. I'll get a rwc with stock tyres then mod it. I was told that 6.5:1 would be good for 33's, so 4:1 is good for 31's? should I get a body lift as well as a susp. lift if I'm using 31's?
Every problem can be solved with a Ratchet.
Post Posted: Mon May 02, 2011 2:57 am
Suspension lift isn't required to clear 31, a 2" BL will clear the tyres. 4:1 gearing will be fine.
Suspension is a minefield for coil sierras. The closer you leave the suspension to stock, the less problems you will have.
Post Posted: Mon May 02, 2011 3:04 am
so just a body lift? will it have good flex and be good for 4x4ing?
Post Posted: Mon May 02, 2011 3:06 am
I doubt it...you would probably need suspension and body lift. Before you ask, look on eBay, the optima kits are great :wink:
Post Posted: Mon May 02, 2011 3:22 am
That's a different problem.
The more flex you add, the more room your tyres need to move. Obviously, with just a BL, you'll only have stock flex. The thing is, aftermarket shocks and springs (on stock mounts) don't add much flex either, but they can improve ride. Improving ride is a different issue to adding flex or running a bigger tyre.
If you don't want to get into fabrication, a bolt on 2" suspension lift will improve ride (a bit) and add a bit of flex, but won't cause cause other problems.
Improving flex doesn't make a huge amount of difference to off road ability. A little bit, sure, but not much. A locker makes much more difference than flex. for me, improving flex is really about improving balance so the car feels more predictable when it's picking up wheels, but the lockers are what's adding capability.
Post Posted: Mon May 02, 2011 9:46 am
what do you have to do to add flex then?
Post Posted: Mon May 02, 2011 9:50 am
Correct springs and bump stops is my guess :wink:
Post Posted: Mon May 02, 2011 10:10 am
4 link front and rear =D
nar... best bet is do a RUF conversion (do a search) and a bigass guard chop.
Post Posted: Mon May 02, 2011 10:12 am
ruf on a coily could be a problem alien
dodgy brothers mechanical
Post Posted: Mon May 02, 2011 10:14 am
making it a leafy would just make it more awesome... lol
Post Posted: Mon May 02, 2011 10:15 am
haha,
a guy in tassie had custom coils made with about 4 inchs of lift, and ran 33 inch thorn birds, seemed to go alright
Post Posted: Mon May 02, 2011 10:17 am
need custom everything to run 4" coils in a coily though.
Post Posted: Mon May 02, 2011 10:20 am
yea i know
Post Posted: Mon May 02, 2011 10:21 am
I'm sure you'd know.
He'd just need panhard rods, dropped castor arms and extended brake lines, dropped pitman... annndddd..
Post Posted: Mon May 02, 2011 12:59 pm
an engineer? =)
Post Posted: Mon May 02, 2011 10:46 pm
different shocks
Users browsing this forum: No registered users and 98 guests
