It is currently Sat Aug 01, 2026 11:27 am
Post Posted: Wed May 04, 2011 4:16 pm
Hi guys i bought a RTC Tough dog Steering Damper for my zook and wanted to share my thoughts about it.
Firstly to those who say that it DOESNT make a noticeable difference i can tell you after fitting the RTC damper i can really say, that my Thumbs are safe from Bump Steer :D
Before with standard damper the zook used to really transfer the bumps and knocks through the steering wheel, this was both a pain in the arse but also took a fair bit to keep it on the straight bumpy roads.
The RTC damper has fixed this for me, my zook feels more enjoyable to drive.
I cant understand how some pull the damper off altogether, that too me really does not make any sense.
So if you are thinking about spending $165 on the damper i reckon it is a pretty good thing. It only takes about 20mins to set it all up and fit.
Please if you think that these are a gimmick let me know i would love to hear your stories.
(I am not trying to sell the RTC dampers i am merely offering my opinion, as i'm sure fellow AZ members could benefit from my review)
Conrad :lol:
I HATE CYCLISTS!!!
Post Posted: Wed May 04, 2011 4:48 pm
Shame you won't need it with power steer :?
Post Posted: Wed May 04, 2011 5:12 pm
Will i still be able to have it on or will it get in the way
Conrad
I HATE CYCLISTS!!!
Post Posted: Wed May 04, 2011 7:02 pm
It won't get in the way, you just won't need it. PS absorbs all the bumps etc, therefore making your dampner redundant.
Post Posted: Wed May 04, 2011 8:01 pm
Are you sure about that?? You could definatly feel the differance in my old GQ Patrol with power steering and a dud dampener, and I've been thinking about fitting one on my Jimny (with power steering), because i've been feeling a bit of bump steer through the steering wheel in that (both offroad and on when driving through large potholes). Maybe power steering does help, but I'm sure it does'nt eliminate it.
Post Posted: Wed May 04, 2011 8:54 pm
I have PS on my jimny and i must say it made a big difference with the RTC on, i would not go with out one...
Post Posted: Wed May 04, 2011 10:20 pm
What condition was your old dampener since you are comparing it to this RTC one?
Lil Foot!
Post Posted: Wed May 04, 2011 10:30 pm
Yep...took mine off and it works a lot better
Post Posted: Wed May 04, 2011 11:39 pm
Yeah I'm not so sure about that. I get massive bump steer on bumpy roads.
09 Jimny Sierra Limited Edition
Vehicle: 4wd
Post Posted: Wed May 04, 2011 11:42 pm
Don't Jimny's come with factory wobble anyway :lol:
Watch out or you'll get sued.
Post Posted: Wed May 04, 2011 11:50 pm
Mine was shit with power steer and no damper, wobbled massively
the damper isnt there for the comfort of your fingers its to absorb energy in the steering FFS why is this so hard for you to all understand?
Post Posted: Wed May 04, 2011 11:52 pm
Missed your morning coffee roycie? :lol:
Lil Foot!
Post Posted: Thu May 05, 2011 12:32 am
Since i have just purchased the damper, i'm def going to keep it on the zook, Hopefully power steering comes today, i have received the BenT Kit which is a bloody good kit.
Conrad
I HATE CYCLISTS!!!
Post Posted: Thu May 05, 2011 12:35 am
how does the tough dog dampner fit up?
if it uses the standard holes in the pitman arm, your gonna have issues cos the vit power steer doesnt have them.
Post Posted: Thu May 05, 2011 12:42 am
He will have to drill the new pitman arm and make a new bracket or remount the damper somewhere else.
I didnt run a damper with vit ps.
If i got wobbles, it was a warning of something was going wrong.
Post Posted: Thu May 05, 2011 12:48 am
drill holes in a cast pitman arm?? thats just asking for it to snap on the holes you drill
Post Posted: Thu May 05, 2011 1:41 am
yes.
Post Posted: Thu May 05, 2011 7:01 am
I used the stock mount on the stock pitman arm and cut it down to fit the vitara pitman arm. It is not bolted, but it is captured when bolted on.
Because the throw is different I made a double sheer mount out of a piece of flat bar and two tabs. Make sure you mount it o you can use all the travel in the dampener or it will ruin your dampener in short order (kinda like shock travel).
I already had power steer, so I did it because I was bored and wanted to see how it worked. I also had an new old man EMU stabilizer from an old tintop I had. It keeps the steering centered, and helps keep it straight on the bitumen/asphalt/black top when the road is rutted. it also seems to ake a difference on corrugated roads.
So yer, it made a difference and I would do it again.
Post Posted: Thu May 05, 2011 7:42 am
Do you have any pics that might help out please.
Conrad
I HATE CYCLISTS!!!
Post Posted: Thu May 05, 2011 7:52 am
will take a look right now. I may have to snap some pics tomorrow if they are not on my hard drive.
Post Posted: Thu May 05, 2011 8:09 am
Please fogive the surface rust I didn't get paint on it right away.
Since the travel was a little different I took a piece of flat bar and welded two tabs on it the width of the stabilizer. Then I took the flat bar, ad welded it to the backside of the stock stabilizer mount.
I cut down the stock non-power steering bracket so it fit behind the little notch. That captures the bracket o you do not have to drill the pitman to get it to work.
It has been working flawless for about a year, maybe two?
I hope this helps, pictures below.
Post Posted: Thu May 05, 2011 8:12 am
mine wobble's, have P/s...
Post Posted: Thu May 05, 2011 8:21 am
PS and no dampener....no wobbles.
Post Posted: Thu May 05, 2011 8:25 am
I had no wobbles before P/S and no dampener, but I worked hard to make everything right (had em at first). I also had no wobbles without a dampener with P/S.
I did
king pin pre load, wheel bearing re-torque, new tie rod ends(half high steer), tire balance, knuckle felts, and set my toe correctly.
T-case arms, and u-joints helped with vibes, but not wobbles.
Post Posted: Thu May 05, 2011 8:53 am
in all fairness if you replaced your dampner with a $50 h/d one you will probably find it would have improved it just as much whilst still being easier to full lock and you would still have $115 in your wallet :wink:
Post Posted: Thu May 05, 2011 9:12 am
Doesn't go Pete :wink:
Post Posted: Thu May 05, 2011 9:37 am
Before :roll:
Might need one with the 33's though :?
Users browsing this forum: No registered users and 291 guests
