It is currently Sat Aug 01, 2026 4:05 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Post Posted: Sun May 08, 2011 11:51 am
I just read the FSM and it did mention bleeding the LSPV for non-ABS vehicles. Bugger...something I didn't realise I had to do.
My brakes work fine and in the wet when I lock the brakes, the front lock up first, which I think is the way it's meant to act as rears locking lead to the end sliding out. With the fronts locking up you skid straight. Sorta like doing skids on your pushie. Is this correct?
2002 SWB GV
Lifted and Locked
Vehicle: Vitara 1995
Post Posted: Sun May 08, 2011 9:47 pm
Mugwui wrote:
Can anyone tell me how to bleed the rear brakes on my GV?
I thought this was going to be a simple job, but I just cannot get the fluid to flow.####
See if anyone make this for your car:
http://www.lowrangeoffroad.com/index.ph ... eders.html
Post Posted: Sun May 08, 2011 11:17 pm
I was thinking about buying one of these hand vacuum bleeder kits instead:
Mityvac
Does anyone have any experience with this brand?
2002 SWB GV
Lifted and Locked
Post Posted: Mon May 09, 2011 1:04 am
Experience with the brand - hmmm - I have one of their vacuum/pressure hand pumps, it looks like the one in the kit, but then they all look alike - I bought it back in January to troubleshoot the free wheel air pump on my GV.
It looks like a well made product and they sell "rebuild" kits so I assume they expect you to repair rather than replace, which I would say is a good sign.
I may or may not get the rest of the bleed kit - might just cobble it together myself - all you really need is an air tight jar and two lengths of the right sized tubing.
Oh - mine is the less expensive plastic version.
Post Posted: Mon May 09, 2011 9:38 am
I've been using one of these for years
http://cgi.ebay.com.au/Lisle-19200-Brak ... 27babceac9
Simple one man operation. connect it to the nipple, pump the pedal, tighten the nipple up when you see clean fluid with no bubbles in the hose. The bottle just stops air getting back in.
My Grand Vitara
Post Posted: Mon May 09, 2011 10:15 am
And dont forget...if the system ran out of fluid completely then there may be air in the master cyl which can cause a spongy pedal. Bleed it where the pipes go in ...loosen the pipe ...pedal down (The brake not the clutch ...that was funny) tighten the pipe pedal up.
Brake fluid should be changed every 12 months ...its hydroscopic and adsorbs water and moister which finds its way the wheel cyls and master cyl and thats what corrodes them.
Users browsing this forum: Google [Bot] and 348 guests
