It is currently Sun Aug 02, 2026 12:26 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
Vehicle: 2018 DMAX
Post Posted: Mon May 09, 2011 8:17 am
Ive got a N70 in mine, pretty easy to fit in. And has enough power to run everything with a dead alt for some time. Only downside is the weight of it.
Vehicle: '94 suzuki maruti
Post Posted: Mon May 09, 2011 8:27 am
Any chance you can get the specs off the battery for me so i can compare it please? :)
Vehicle: Jeep
Post Posted: Mon May 09, 2011 8:28 am
whincup wrote:
DONT FIT IT THAT WAY!!!!!!!!!!!!!!!!!!!
your bonnet is about to catch fire :)
as in, rotate it 180 degrees? i closed it slowly and watched as i was doing it, theres about 1cm between top of terminal and bonnet. and i use a cut up bike tube to cover the terminal in case the battery clamp breaks...
and after the amount this things cost me the last few months, i might actually be glad if it catches fire :evil:
I agree with Royce, its a fire hazzard in the making :blink:
Yes turn it 180, so battery terminals are towards the engine, quick turn it around, turn it around !!!
1cm 8O Jeez... the battery could easily jump up that much when 4wheelin, and that bike tube rubber, is wayyyyy to thin !... get some reinforced rubber sheet, much thicker and stronger... :wink:
I dont know what the Optima batteries are like for vibration resistance, as it can kill an ordinary battery very quickly... but i would get a battery that is built for 4x4/Marine use, built tougher for vibration, if you go 4wheelin alot... :wink: :D
Vehicle: 2018 DMAX
Post Posted: Mon May 09, 2011 8:34 am
Its a N70ZZL, 660CC, 140RC. 300L x 170w x 230h. Has more than 25mm to the bonnet depending on the terminal size, and with the new clamp is used it aint going to fall out.
Post Posted: Mon May 09, 2011 8:54 am
christover1 wrote:
I was a passenger in a mates car, it had the battery under the seat.
Nobody as big as me had travelled in it before.
Travelling well, bum started getting warm,
then smoke came out of back of seat.
He never let me in his car again :)
PS my man bits survived ok ;)
Did you have a few curries the night before?
2002 SWB GV
Lifted and Locked
Post Posted: Mon May 09, 2011 8:57 am
I don't need curries to start fires :oops:
Post Posted: Mon May 09, 2011 11:08 am
haha dont worry i havent been driving with it like that. i only put it there to test how it fits, i still have the standard size sierra terminals so i couldnt even if i wanted to... but the last supercharged brand battery i had lasted quite well, and i get them cheap-ish... plus they have a 36 month warranty.
i'll attach some kind of thick rubber to the bonnet above the battery.
Vehicle: Jeep
Post Posted: Mon May 09, 2011 1:12 pm
Ha ha, ok :wink:
My battery died soon after i bought my GV :roll: thankfully a local Auto store was havin a battery sale, got a Supercharge, maintenance free, 520CCA, Silver, for $100, was a bargain i thought, and yes, they do have the 36month warranty... :wink: :lol:
Post Posted: Mon May 09, 2011 1:24 pm
Just make sure it is tied in good and well, bungee's don't count armsup
I know it shouldn't have to be said, but I have seen two rigs now catch fire due to a lack of tie downs, or a broken bungee cord.
Iffen' ya battery gets drained down almost to nothing, it may be hard on the alternator as well. It depends o how much of a charge that battery will take when it's near flat.
So if ya batter is flat, don;t rev up the engine too much until the battery has got a bit of a charge in it.
Users browsing this forum: No registered users and 1256 guests
