It is currently Sun Aug 02, 2026 4:09 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3
Post Posted: Tue May 10, 2011 9:13 am
i have 3 leafs in the front took load leaf out and i have 2 in the rear is that good no extended shackles ill show progress when i make a build thread thx guys
Post Posted: Tue May 10, 2011 9:31 am
This is a bit of a problem with King leaves as far as I have seen - they're way too tall.
I think that with 2 leaves only in the rear, you might struggle with axlewrap, for the same reason, you might not be able to run less than 3 leaves in the front.
Your ute chop isn't helping - it's making the car nose heavy.
See how you go. You could always get the leaves de-cambered (flattened out) a bit by a springmaker.
Post Posted: Tue May 10, 2011 10:09 am
just put a crapload of weight on the tray for a few weeks =) the springs will sag in no time.
Post Posted: Tue May 10, 2011 9:46 pm
yeah i need to make a 2 inch roll bar yet and a petrol tank under tray over axels so it evens it out a bit and spare tyre shoudl be good might just leave 3 leafs and put some weight on it
Users browsing this forum: Google [Bot] and 268 guests
