It is currently Sat Nov 07, 2026 3:42 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2  Next
Post Posted: Fri May 20, 2011 9:12 am
Hey guys,
Did a big search on weird, odd, bad terrible sounds coming from my drive train, and all the results came back weren't quiet like mine is.
No Noise in first when driving, tiny little bit in second, sounds faint, get into third, no noise until I accelerate, then it sounds like howling coming from underneath me, in fourth it's really terrible, gets louder and more high pitched. Soon as I back off the noise stops completely. Only comes on again when I touch the accelerator pedal. Is this an input shaft bearing in the gearbox that needs to be replaced? Any other ideas before I go nuts?
sogone.
Post Posted: Fri May 20, 2011 9:20 am
mine had a similar problem it was the transfer case
cheers luke
found out after i replaced gearbox :oops:
Post Posted: Fri May 20, 2011 9:54 am
I'd be looking at transfer first, look for oil leak's & level.
If you oil's white & over full it's likely to be full of water.
But!!!!! Look at all of your oil's......
Vehicle: LJ20 LJ50
Post Posted: Fri May 20, 2011 9:56 am
I'd say transfer case. Normally hardfacing weras away and the box is a throw away. Nomater how many new bearings noise all the time.
Or get a new set of crawler gears :-)
Camels have nice toes
Vehicle: 91 WT 1.6EFI
same thing here.. I have a new rear diff going in next week. I'll let yous know if it sorts it out
Post Posted: Fri May 20, 2011 9:58 am
have you checked all your uni joints
Post Posted: Fri May 20, 2011 10:11 am
yep, mine are frucked.... :helloo:
Post Posted: Fri May 20, 2011 12:44 pm
News unis and all. Second hand tranny. Will check oil sunday to see if theres oil in it, if not Maybe input shaft bearing?
Post Posted: Fri May 20, 2011 12:58 pm
I will also look for water in it sunday. But it really sounds like it's coming from the gearbox, not tranny. I have breathers in both above the engine so I don't know how?
Post Posted: Sat May 21, 2011 3:43 am
Doubt it lot's........
Swb?? rear diff's are just behind you to, does the noise increase in pitch with speed????
Post Posted: Sat May 21, 2011 3:54 am
Mine does and it has sort of a grinding/meshing sound at slower speeds. I have hung my head out the back while driving and it definitely sounded like it was coming from the diff.
Post Posted: Sat May 21, 2011 4:06 am
It increases with revs... soon as you back off the accelarator even slightly the noise stops. IF the clutch is in when your rolling there is no noise at all. Doesn't do it in first, very very very faint and only higher in the rev range in second, soon as you put it in third and touch the accelarator it makes like a shimmering grinding noise that sounds similar to a super charger whine but just increases as you put it through the revs.
Post Posted: Sat May 21, 2011 4:18 am
so what your saying is that the noise sounds different doing 100kph in 3rd and 100kpm in 5th?
Post Posted: Sat May 21, 2011 4:49 am
I'd like an answer to this....
Post Posted: Sat May 21, 2011 5:54 am
That is correct. It's not the speed it's the particular gear and the rev's that it is doing that determines the pitch and level of the sound. And only when there is accelaration applied, All be it just feathering the pedal will bring the sound on.
Post Posted: Sat May 21, 2011 6:01 am
hmm righto I'm going to test this on my way to work tonight. I do know that 80 sounds the same in 4th and 5th on mine but I'll have a go at 3rd and 5th and see.
Post Posted: Sat May 21, 2011 6:17 am
How loud is your rosco? People can hear the sound while im driving at 80km/h towards them, they look back when im about 40 metres behind them. So im assuming it is really audible. It's really really loud in the car also.
Post Posted: Sat May 21, 2011 6:24 am
its pretty loud on the highway you have to talk pretty loudly to talk over it. dunno about people being able to hear it outside the car though. have a look here this was the previous thread on this general topic. http://www.auszookers.com/index.php?nam ... eing+noise
abclarke replaced his rear diff and it was sorted so thats what I'm having done on thursday
Post Posted: Sat May 21, 2011 6:27 am
Just replaced all my diffs mate, definatley not coming from the diff or it would be a constant sound and would be speed based.
Post Posted: Sat May 21, 2011 6:30 am
hmm ya I think mine is speed based but I guess well find later in the week :) if it doesn't work might move on to the transfer bearings
Post Posted: Sat May 21, 2011 6:41 am
Your transfer geared????
Post Posted: Sat May 21, 2011 6:42 am
Nope. Had a geared one, but blew it to peices. Just a stock box pulled out of a wreck.
Post Posted: Sat May 21, 2011 2:05 pm
ok so my noise is the same going 80kph in 3rd 4th and 5th. Definitely speed related. sorry sogone our issues are in fact not related :)
Post Posted: Sun May 22, 2011 8:39 am
Any ideas??? Knifie?
Vehicle: Daisy
Post Posted: Sun May 22, 2011 8:54 am
From your description if I've read it right (i.e. changes with speed but not engine revs) It has to be something between the output of the gearbox and the wheels.
Have you revved it with the transfer case in neutral? That could tell you more in that only the input and counter shaft would be spinning in the transfer.
Also, if you haven't already, test it like Rossco did by doing the same speed in each gear and see if the noise changes.
Post Posted: Sun May 22, 2011 10:47 am
i had tha same prob with mine when i put my 6.5.1 and new bearings in all good . so i would say its tha gears are worn or tha bearing
2''lift 31's twin locked & 6.5s
Post Posted: Sun May 22, 2011 12:39 pm
Yeah tried it... It's not speed based... it's rev based x gear. You've read it wrong Teracis. It's either tranny or G/box I hopes :\. Anyone else had same probs?
Post Posted: Sun May 22, 2011 12:45 pm
that would be my guess. probably a bearing somewhere.
Vehicle: Daisy
Post Posted: Sun May 22, 2011 7:55 pm
Cool so if the noise changes for different gears at the same speed then you're right it has to be gearbox related.
Could it be the thrust bearing for the clutch that everyone seems to talk about?
I wasn't present when my clutch was swapped over in my engine swap (had to go to the shop) so I have NFI where the bearing is.
I'm probably wrong though, because iirc the thrust bearing is a noise that changes depending on whether the clutch is in or out.
Post Posted: Sun May 22, 2011 8:10 pm
Drove my vit on the highway yesterday and holy shit.....my radio isnt loud enough to cover my noise.
It's on in 3rd and 5th. Noise goes away on declaration. However, when slowing Down for lights in 3rd (foot off pedals) the noise will be faint but come on and off.
Mines not a whine just a really loud grinding noise.
Any ideas?
Users browsing this forum: No registered users and 28 guests
