It is currently Sat Jul 18, 2026 3:01 pm
Post Posted: Thu May 19, 2011 11:14 am
Gone through shed again and its time to get rid of more junk, and clear space for the build!
Also have 3 sets of Transfer arms $20 per set.
GV
J20A radiator and fan and shroud $50
came from running car so should be ok, rad is not in prime cond.
GRAND VITARA FRONT BRAKES $50 Disk and Calipers, great cond!
Sierra
Baleno or swift (not sure) Front seats OK Condition $50
2pin center good nic, $30. (came out for airlocker)
Contact via PM.
Will freight at BUYERS risk, there will be a charge for my time etc.
Buyer to organize the freight company.
Location is 3199, Vic
Pics on Request, they are taking ages to load so I will just put up the ones you need.
Post Posted: Thu May 19, 2011 11:44 am
the 2 pin ctr. is it 22 or 26 spline. if its 26 ill take it.
Vehicle: SJ40T + Coily
Post Posted: Thu May 19, 2011 11:45 am
long shot but can i have the flanges (WT) off the t/case or any spares you might have? $?
Post Posted: Thu May 19, 2011 11:46 am
mmm good question! I think it came from the front one so prob a 22?
Post Posted: Thu May 19, 2011 11:47 am
Sorry mate Im in the same boat! Im gunna have to find some also.
By the way whats the difference?? Bolts holes line up as far as I know but what else?
Post Posted: Thu May 19, 2011 11:50 am
Sorry!~
Someone just sent me a PM and I deleted it before I read it!
Please send again!
Post Posted: Thu May 19, 2011 12:01 pm
I'm trying to find out for sure without tearing the transfer out of my mates. But I've been told that the NT flanges are a smaller diameter and a different bolt pattern to the WT ones. Apparently you can still drill NT's to suit a WT or coily driveshaft. I'm trying to confirm this before I go any further though.
As for coily flanges, they fit on the same splined shaft but part of the flange is the actual sealing surface, and they are much shallower, so when you put them on a WT transfer and whack the nuts on, the flanges slide back and forward heaps.
Lowrange has new ones but at $89 each they can get fucked.
Post Posted: Thu May 19, 2011 1:42 pm
Yeah narrow track flanges have the holes abit closer to the center, which is why you cant just put the WT shafts on them.
The good news is that the collar that locates the shaft into the center is the same size, which means you can slot out the NT holes or drill in new ones and the shaft will locate in the right spot and not vibrate.
Post Posted: Thu May 19, 2011 8:57 pm
Just unbolt the NT flanges from the transfer and fit the WT flanges from your old transfer, problem solved.
Post Posted: Thu May 19, 2011 10:05 pm
is there a way you can measure what is what?
I have about 6 shafts here and 3 TC cases, just trying to figure out what is what!
Post Posted: Thu May 19, 2011 10:21 pm
NT flanges have M6 tailshaft bolt holes for 12mm headed bolts and a trans brake.
WT Flanges are M8 and a larger bolt spacing on there flanges for the 14mm bolt
WT tail shaft yokes are the same as SJ80 & Vitara
Post Posted: Fri May 20, 2011 3:44 am
Would do that but i drive a coily. :@
Post Posted: Fri May 20, 2011 11:29 am
Also have
2 x 2pin centers and are 22 spline.
Let me know if you want them, come and get them!
Post Posted: Sat May 21, 2011 11:34 pm
All going on ebay today
TC sold
Post Posted: Sun May 22, 2011 2:35 am
Towbar gone
Post Posted: Sun May 22, 2011 11:17 am
Feel Free to ask for a package deal.
All items now listed on ebay also.
Post Posted: Wed Jun 01, 2011 10:23 am
Updated
Users browsing this forum: No registered users and 96 guests
