It is currently Sun Aug 02, 2026 5:36 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Tue Jun 14, 2011 8:15 am
my sierra does it at about 50-65km/h under or above that speed and its fine
suzuki sj70+2 inch lift+ 2ich body lift+ el falcon
Post Posted: Tue Jun 14, 2011 8:23 am
monkey wrote:
Ok Suzuki put more pre-load on my king pins and added some toe in camber and the wobble is almost gone now 8) just the tyres need a balance then is should be gone :D . They would how ever not add shims under warranty unless i took the car back to stock :? but oh well at least the wobble has gone :P
how do you put pre-load on king pins?
Post Posted: Tue Jun 14, 2011 8:36 am
steak_knife wrote:
Wow, really????? :roll:
Yep! It they would charge me a arm and a leg if i was to pay for them, dose that sound right? They were trying to talk to "suzuki Australia" about the issue today and see of they would do it if i had stock rim back on, but they would only do it with stock suspension back on and rims :?
They also said they had 3 other jims in today getting shims fitted and non of the shims fixed the wobble, i think they are spinning a bit of bull shit here. :x
Post Posted: Tue Jun 14, 2011 9:31 am
Ok, after talking to Paul, I have decided to order a couple of sets from BigJimny in the UK.
SS does not believe shims will make any difference... but its the only thing I have not tried.
Post Posted: Tue Jun 14, 2011 9:42 am
Add shims between the KP bearing and the KP. In a nutshell it squashes the bearing slightly causing more friction and snugger fit.
APIO have adjustable KPs for over $200.
Post Posted: Tue Jun 14, 2011 11:30 am
I have a feeling thats per pair (per side) as they list them as 'Right Side' etc
I might gwt 2 sets of shims and also a set of Annealed Copper Washers as well. Just to try at some point.
Post Posted: Tue Jun 14, 2011 7:23 pm
i thought you had to add shims to add load to the king pin. just later on, on monkey's post he said they would have added shims only if his car was stock. thats just where i got confused.
Post Posted: Tue Jun 14, 2011 8:19 pm
I think they meant they'd only shim it under warranty if it was stock
Users browsing this forum: No registered users and 48 guests
