It is currently Sun Aug 02, 2026 1:17 am
Vehicle: LPG 1.6 Sierra
Post Posted: Sun Jun 12, 2011 3:52 am
I gotta give my heaterbox a clean out. Seems to work fine but no force to the air coming out.
How do you take out the dash? I don't want to fully pull it out - just enough to access the airbox?
Post Posted: Sun Jun 12, 2011 4:19 am
pull the steel bar thingo that runs along the bottom of the dash out
from the engine bay side you need to pull the heater hoses off where they go into the firewall along with the nut beside it
then pull the control cables off the bottom of the heater box and see if thats enough to wiggle it out to where you can get at it
otherwise pull the column out, speedo out, stereo out, then the screws along the top of the dash
Post Posted: Sun Jun 12, 2011 8:38 am
Or take the easy option. http://www2.izook.com/?page_id=258
When i did mine i got a rubber floor plug from the wreckers to plug the hole when i was done so now i can just pull the plug and clean it whenever.
Post Posted: Tue Jun 14, 2011 11:37 pm
That was a shitty job, but at least I got a demister now :?
Didn't help to have an air con box to make it all 10x trickier
Vehicle: 85 Suzuki Sierra
Post Posted: Wed Jun 15, 2011 11:42 am
Question? - if this was blocked up could it stop the hot from working?
Or may that be blocked up somewhere else :/.
Orange LWB Sierra
Post Posted: Wed Jun 15, 2011 11:44 am
yeah thats exactly what happens, because sierras only heat through floor and demist settings the heater core is at the base of the air intake plenum, it fills with leaves and blocks any air passing through it to heat
Post Posted: Wed Jun 15, 2011 1:30 pm
Ah sweet. Drilling through the side of it looks like the way to go :)
Cheers!
Orange LWB Sierra
Users browsing this forum: fordem, Google [Bot] and 1117 guests
