It is currently Fri Nov 06, 2026 6:52 pm
Post Posted: Thu Jun 16, 2011 4:03 am
I changed my rear bushes & shocks a few weeks back for a bush trip I took this weekend. I used the black rubber ones on ebay.
While i was changing a tyre I noticed that one of the 3 bushes had torn loose on both sides, pretty much the same as why I replaced them initially.
Is this a common problem?
I was only driving dirt roads with the odd rut here and there, there was a long section that was a little bumpy - but hardly what I expect to cause instant failure.
Is there a more hard wearing product available?
Could it be the springs are sagged so much that the bushes are copping a flogging?
Post Posted: Thu Jun 16, 2011 6:59 am
What car? I would suggest the bushes you bought may be of a cheaper quality rubber. They should last for quite some time. I would be recommending nolathane bushes, far betterer!
Post Posted: Thu Jun 16, 2011 7:06 am
Or contact the seller and demand refund :wink:
Vehicle: 2018 DMAX
Post Posted: Thu Jun 16, 2011 7:09 am
When i ran cheap rubber bushes in my springs, with out lube they died within 1000kays.. (as in, no bush left at all).. i then ran cheap bushes with a decent serve of HTB grease i had laying around, inside and outside the bushes and they lasted around 2000kays until i removed them, they were still in great condition. The nolathane bushes i used in the top shackle mounts have yet to wear and were in from the beginning.
Post Posted: Thu Jun 16, 2011 7:43 am
Firstly, the flanges on bushings should last more than 1000km. However, if the bushes are loose in the springs, your shackles are worn or have no centre bars, or you lubed them with petroleum based grease, it's not all that remarkable.
Boostedbrick - HTB grease destroys rubber. Rubber bushes shouldn't require greasing, but if you do, use rubber grease.
Vehicle: 2018 DMAX
Post Posted: Thu Jun 16, 2011 7:48 am
Fair enough, i got told by the bloke at pedders not to use it on the nolathane ones, but was fine on rubber.. But pedders is pretty bloody useless either way.
Post Posted: Thu Jun 16, 2011 7:54 am
pretty sure it's a coily going by his avatar.
Post Posted: Thu Jun 16, 2011 8:06 am
You can get replacement rubber bushes for coilers? That's news to me.
Post Posted: Thu Jun 16, 2011 8:09 am
A company on ebay is the only place you can get them unless you go genuwine. I'll be getting a set or two very shortly.
Post Posted: Thu Jun 16, 2011 8:27 am
Which was kind of my point - the stock bushes aren't replaceable according to suzuki - flogged bushes=repalcement arms AFAIK
Post Posted: Thu Jun 16, 2011 8:31 am
I rang Zupps, they were asking $46.50 per bush.
Rang another dealership (can't remember name) they told me the part didn't exist and I had to buy a whole arm at a price of $754.60 each.
Post Posted: Thu Jun 16, 2011 8:38 am
the part numbers for genuine rubber ones. Bush where arm attaches to diff is SZ4628281A30 and bush where arm attaches to the chassis is SZ4621365D01
Post Posted: Thu Jun 16, 2011 9:05 am
97 coily is the car.
do you think these poly ones would be an improvement on the rubber ones i got?
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 106wt_1139
Can't find any made of nolathane for a coily.
Does any exist? If its the hardest wearing option, I want em.
Post Posted: Thu Jun 16, 2011 9:31 am
Only if you can reinforce the axle brackets - in my experience urethane bushes break mounts on coilers.
Post Posted: Thu Jun 16, 2011 9:37 am
reinforcing anything is beyond me.
think i'll get the poly ones and see how they go.
could hardly be worse than the ones i had.
Is there anyone in Sydney that could be recommended for doing custom mods/mechanical upgrades on Suzukis?
Post Posted: Thu Jun 16, 2011 9:53 am
Poly bushes could be far worse than rubber. Broken axle brackets really suck - tow truck material.
Flogged rubber just makes the car drive loose.
I'd be ordering factory replacement rubber.
Post Posted: Thu Jun 16, 2011 1:32 pm
done some reading & I see what you mean.
this coily is clearly going to do my head in.
Vehicle: SJ80, SE416
Post Posted: Fri Jun 17, 2011 6:20 am
X2 on the rubber bushes.
I've been lucky so far, both time I have had axle mounts fail I have seen the damage at an inspection before it has completely failed.
IMO, Nolathane bushes are alright if the car is only used on-road, but if it is used off-road, expect at least 1 cracked bush in less than 30,000km.
I'm running second hand jimny arms with original rubber bushes in the front of one of my coilies at the moment and they haven't developed any noticable cracks so far.
Users browsing this forum: Google Adsense [Bot] and 64 guests
