It is currently Wed Jul 22, 2026 8:21 pm
Post Posted: Fri Oct 03, 2008 1:22 pm
The Power windows in my Vit make a HIDIOUS Finger nails down the black board noise when you push the button to go down..
Anyone else have the problem and if So How did you solve it ?
It Seems to be the window itself and not the rubber tracks it slides down ?
And yes.. the windows are clean..
Post Posted: Fri Oct 03, 2008 1:28 pm
Pull the inside door skins off and check there is nothing rubbing on the glass. You can use graphite powder in the rubber channels to lubricate them too.
Post Posted: Fri Oct 03, 2008 1:29 pm
windows arent clean, hit em with metho and then window cleaner, they will have raod grime window cleaner wont budge
clean the rubbers too and maybe put some dri lube on and then clean off
ther is something that really good for shutting them up but I cant remember what it is
Post Posted: Fri Oct 03, 2008 4:15 pm
half doors do the trick :lol:
Web wheeler extroadinaire
Vehicle: LJ20 LJ50
Post Posted: Fri Oct 03, 2008 7:50 pm
dri lube stick
Camels have nice toes
Post Posted: Sat Oct 04, 2008 5:25 pm
Thanks Guys.. Will hit the windows with Metho then window cleaner
I have applied Graphite powder to the tracks and they are silky smooth.. Window might be out of alignment as its the only thing I can think off..
Users browsing this forum: Google [Bot] and 355 guests
