It is currently Sun Aug 02, 2026 9:09 pm
Vehicle: Sierra Ute '87 Sj70
Post Posted: Wed Jul 13, 2011 9:42 am
hey ive got a couple of questions
1st. what do you guys do when your body mounting plate's (the cone section) is broken?
2nd. how and what have you fabbed for a roof console?
3rd. what coulor should i paint my ute?
4th. what do i use for extended bumpstops? (im running 30's)
5th. what can i use for a cheap alternative for a long range tank for under my tray?
It's all coming together Armsup
Post Posted: Wed Jul 13, 2011 9:56 am
#3 Pink
#4 RHS or SHS
Post Posted: Wed Jul 13, 2011 9:59 am
#3 Pink
x2
:blingbling:
Post Posted: Wed Jul 13, 2011 10:02 am
1st. what do you guys do when your body mounting plate's (the cone section) is broken? I'd fix it by welding I'd say
2nd. how and what have you fabbed for a roof console? don't need one
3rd. what coulor should i paint my ute? Bright pink
4th. what do i use for extended bumpstops? (im running 30's) RHS Tube
Your kidding I hope. You want to fiit a cheap 1/2 arsed alternative tank? Mate loneranger might be able to help you with a SAFE long range tank.
Post Posted: Wed Jul 13, 2011 10:03 am
Haha I was thinking yellow or black
(Its not a vit)
Post Posted: Wed Jul 13, 2011 10:11 am
I wasn't gunna hook some dodgy ass tank but others have got some to fit and I was asking for some ideas,
I was gunna have a roof console becasue as you might know there isn't much room in a zook ute.
Post Posted: Wed Jul 13, 2011 10:14 am
#3 CYAN
Post Posted: Wed Jul 13, 2011 10:18 am
#3 CYAN
That could work
Vehicle: 96 sj70+80 tintop sierra
Post Posted: Wed Jul 13, 2011 11:05 am
Get a Jerry can and zip tie it in....
Post Posted: Wed Jul 13, 2011 10:37 pm
Not a bad idea why didn't I think of that
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Thu Jul 14, 2011 1:37 am
I had mine up against the back door.
Eye hooks and a strap.
This was after several huge woops, hence the little tilt, but, cheap and reliable.
Post Posted: Thu Jul 14, 2011 1:48 am
i have seen skyline and jackaroo tanks used in utes,
but it will involved fab work.
Post Posted: Thu Jul 14, 2011 9:29 am
i wouldnt be able to weld the body mounts there is nothing to weld back in the have of the cones are broken off but the flush top parts are still perfectly good
Post Posted: Thu Jul 14, 2011 9:32 am
http://www.auszookers.com/index.php?nam ... ic&t=16859
this is my tray
Post Posted: Thu Jul 14, 2011 9:38 am
TANK: Get a 95 Jackaroo tank if you need EFI. Or get a tank from the carby Jackaroo ( same tank, just no EFI pump). Mounts up very nicely between the rails, and 85L capacity is great! Got my carby one for $100, EFI one for $200 inc pump.
EDIT: Tank won't fit with the spare dropping through your tray like that.
ROOF CONSOLE: Its not finished, but the frame work is there. This is in my ute. I needed the space for my left knee. :roll:
Post Posted: Thu Jul 14, 2011 10:12 am
i moving the spare i dont like it there
can i get a carb tank and put a efi pump in later
can you post more picks on the mounting of the console?
Post Posted: Thu Jul 14, 2011 10:19 am
i was looking on low range and found this for my front clip but my question would be, would this be the same as one out of a 1lt because i have a 1lt clip with a bit of cancer and a 1.3 but prefer the look of 1lt, so instead of buy this could just swap between clips and weld in?
http://www.lowrangeoffroad.com/index.ph ... ement.html
Post Posted: Mon Jul 25, 2011 10:07 am
still need help with last question
Post Posted: Mon Jul 25, 2011 11:33 am
I've heard that they alter the metalwork to make it fit a Samurai. It seems likely, I have just fitted a Sierra (Samurai) front clip on my SJ413K and the original front grill doesn't fit.
As I have, most likely, the only Sierra front clip in the UK I'm hoping that its an SJ413/Samurai difference and not an Aus market variation.
I'll be watching the roof console project, I need the space for my left knee too.
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Users browsing this forum: Beery and 305 guests
