I pretty sure coil calipers are the same as vitara, so they should fit, but the bleed screw is in the wrong spot - you'll have to take the caliper off and rotate it to bleed the brakes.
They are not an upgrade though - AFAIK they are still solid rotors and and pads are the same size.
Users browsing this forum: No registered users and 68 guests
