It is currently Fri Nov 06, 2026 10:03 pm
Post Posted: Sat Jul 16, 2011 4:45 am
hey guys. trying to put some fuel injection on the sierra and having troubles with not getting any fuel to squirt out. the pump will prime when power is givin but wont run when cranking. ive done the dizzy mod and is connected properly. any one got any ideas?
ive had a read through this http://www.auszookers.com/index.php?nam ... hlight=tbi
but still not happening.
cheers
Post Posted: Sat Jul 16, 2011 7:47 am
is the dizzy earthed? this will stop the fuel as well. or the tacho wire connected to the ecu(mine was a brown wire)? this is what was stoping mine.
Post Posted: Sat Jul 16, 2011 8:01 am
no brown wire with mine but dizzy is not earthed...will try it now
Post Posted: Sat Jul 16, 2011 8:16 am
how did you earth yours?
Post Posted: Sat Jul 16, 2011 8:59 am
just tap off from the black wire from your dizzy
Post Posted: Sat Jul 16, 2011 9:33 am
still nothing :( where am i supposed to be getting power?
Post Posted: Sat Jul 16, 2011 9:50 am
having a srearch on the net i may have found my solution. when i got everything the igniter didn't come with a plug so i had no idea where the wires went. i looked on the wiring diagram and solderd wires on to where i thought they were ment to go. but i may be wrong. does anyone know what wires are supposed to go where? cheers.
Post Posted: Sun Jul 17, 2011 8:26 am
still not going. pretty sure ive ot everything plugged into where it needs to be but when i put a multi meter on the cas and crank it i get nothing. ive removed the black box and pluged the wires strait into the CAS wires for the ecm. is there anything im missing?
Users browsing this forum: Google [Bot] and 118 guests
