It is currently Sat Nov 07, 2026 12:23 am
Post Posted: Sun Jul 31, 2011 11:35 pm
I have a couple of electrical faults in my 08 Jimny.
The horn is not working. Fuse OK. No voltage at the horn when activated. What else could it be. I didn't want to play with the steering wheel air bag till I kmew what I was doing. Should I disable the air bag control unit underneath at the top of the column before I start? Or is there another possible cause?
Airbag dash light. This has been on for a while, and predates the horn failure.
HIDs sometimes do not both turn on. I think this is voltage related. I find I need to have the revs up to ensure they both fire. I've got 20AMP wiring to the relay and lights.
Extra wiring. Where to put an extra fuse rack. Little room under the bonnet, with air box, brake booster, ABS, ARB pump etc. Is there such a unit as a spade fuse panel with the all terminals (entry and exit) on the one side, or underneath, or perhaps common rail?
Exhaust. I have a rather large muffler under the rear which I have hit on a rock, and is now deforming my panhard. Is smaller muffler (say half the size) that would still keep the noise to a minimum?
Post Posted: Mon Aug 01, 2011 3:40 am
Check for voltage at the horn terminals, mine wasnt working and it turned out to have crud inside the body.
Post Posted: Mon Aug 01, 2011 9:32 am
I think its pretty clean, but I will do that tomorrow.
Squizz... Is thata Turbo in your Jimny???
Post Posted: Mon Aug 01, 2011 9:59 am
Nah, that's a photo-shop limited edition leb special.
Post Posted: Mon Aug 01, 2011 10:14 am
? Could be lots of causes, for sure there's no power at the horn?
Maybe body lift has stretched or disconnected something
I don't have any volt supply issues, alternator ok? Sounds like something is affecting a range of components.
ABS under the bonnet wastes a heap of space. Mount stuff to the underside of the bonnet maybe.
You're too rough with your muff :D
Post Posted: Mon Aug 01, 2011 10:19 am
Btw when are you gunna start a proper build thread
Post Posted: Mon Aug 01, 2011 7:00 pm
I really didn't take enough photos during the build. I tried but got lazy.
Oh, and reading your ABS comment, I almost thought you were gonna suggest ditching it :twisted:
Post Posted: Mon Aug 01, 2011 7:05 pm
I am looking forward to when I kill the motor and I can put a 1.8L Liana motor in (or whatever is the best match upgrade)
:peaceout: pompoms yess!!
Post Posted: Mon Aug 01, 2011 8:44 pm
why wait till you kill it? At the moment it still has value.
Post Posted: Tue Aug 02, 2011 12:19 am
If airbag and horn with issues I would suggest clockspring (or whatever suzuki call it) failure
Post Posted: Tue Aug 02, 2011 11:48 am
I don't know what that is.
Users browsing this forum: No registered users and 100 guests
