It is currently Wed Jul 22, 2026 9:29 pm
Vehicle: 30s front locker barwork
Post Posted: Tue Oct 28, 2008 10:30 pm
hey guys i hav some weird noise comein from the steering wheel it like it it rubing on something has any one else had this problem bcoz it is quiet anoying
Vehicle: MY2019 Jimny
Post Posted: Tue Oct 28, 2008 10:51 pm
Maybe your steering wheel is rubbing on something...
Post Posted: Wed Oct 29, 2008 12:39 am
Uni joints probably, what condition is the rag joint?
Post Posted: Thu Oct 30, 2008 11:36 pm
how do i tell the conditon of it
Post Posted: Thu Oct 30, 2008 11:38 pm
look at it - if it looks ratty, and you can bend it by hand easily, it is probably rooted.
Post Posted: Fri Oct 31, 2008 12:22 am
okay cool thanks
Vehicle: 98 coily..Max.
Post Posted: Fri Oct 31, 2008 12:24 am
Might be a mouse in there....
Suzuki...four wheel jive!
98 coily...Camping rig.
Post Posted: Fri Oct 31, 2008 1:05 am
More likely the bush in the steering shaft by the sounds of that description.
How many KMs on your zook?
Post Posted: Wed Nov 05, 2008 4:27 am
OMG LOL I HAVE HAD THE EXACT SAME THING.
i was 4x4ing in mud etc and then it started...very annoying.
i jumped under the card and sprayed some thing with WD40...worked well
Nissan Recover Vehicle
Post Posted: Wed Nov 05, 2008 1:49 pm
i've had a similar problem. Everytime i dry steered it would make a horid creaking noise. Turned out to be the springs moving and the noise was the friction pads rubbing on the springs, a little dry lube between the springs and the noise went away.
Vehicle: '92 Sierra
Post Posted: Wed Nov 05, 2008 2:33 pm
+1 vote steering uni -joint
Post Posted: Wed Nov 05, 2008 3:35 pm
i had the same.. my hard line going to the left hand side was bent up a bit to touch the draglink etc
mines a NT if that helps..
Post Posted: Fri Nov 07, 2008 9:02 pm
goin to go get a another uni joint tomorrow were is the steerinfg bush
Users browsing this forum: No registered users and 373 guests
