It is currently Sat Nov 07, 2026 10:34 pm
Post Posted: Fri Aug 12, 2011 10:23 am
Hey guys, i have searched to no avail.
My headlights (glass) are really dull and foggy looking. Is there a way of getting inside and giving it a erally good clean to make it more transparent or is there legal issues with something like that?
Mitch.
Post Posted: Fri Aug 12, 2011 10:34 am
is it inside ??
thee get a glaze on the outside.. many ways to fix that.. but have been using a rejuvination kit that you can get from repco..
they come up pretty good.. just take your time.
got an pics of the foggy??
Vehicle: 2001 Jimny M13A
Post Posted: Fri Aug 12, 2011 11:37 am
I don't think Jimny's have glass headlight lens, they're polycarbonate.
If they're "dull and foggy looking" it's more then likely the surface has deteriorated or been scratched.
My second hand Jimny's lights looked like frosted glass from an
ill conceaved atempt to clean them like they were glass, but it easily fixed as tiptop said, with the right stuff and a bit of elbow grease.
Post Posted: Fri Aug 12, 2011 12:03 pm
I just use 800 and then 1200 wet and dry with water and then use cutting polish number 1 then 2 with my buffer. Then to finish it up nicely I just use a hand applicator with some wax (no cut). Comes up like new.
Post Posted: Fri Aug 12, 2011 1:40 pm
Been sworn to secrecy but I may have seen a mate who is a very experienced spray painter buffing a car and doing the same on all of the lights, looked brand new...
That is bucketload of stupid questions, not cash!
Post Posted: Fri Aug 12, 2011 10:11 pm
great story mate, thanks for the info :roll:
Post Posted: Fri Aug 12, 2011 11:59 pm
Ordinary cutters and lambswool buff the way to go. The speedshop kits are about $30.00. dreamin.
Post Posted: Sat Aug 13, 2011 12:17 am
Check out this thread for headlight cleaning:
Cleaning candles
2002 SWB GV
Lifted and Locked
Post Posted: Sat Aug 13, 2011 12:43 am
Hey Birdman, I forgot to ask, what type of globes are you running?
If they aren't designed for polycarbonate lens headlights, they will stuff your lens, from the inside out!
Which would mean new headlights - save some on shitty globes only to spend shitloads latter when your lens melt or break down.
Vehicle: Jimny!
Post Posted: Sun Aug 14, 2011 1:43 am
Yep, you'll find they're plastic.
Here's what i did, worked a treat.
http://auszookers.com/index.php?name=Fo ... ic&t=23962
If indeed they are glass for some reason, get some 00 grade steel wool from a cleaning shop, that'll get stains off, not scratches or sandblasting though.
Post Posted: Sun Aug 14, 2011 2:13 am
[flash width=480 height=385]http://www.youtube-nocookie.com/v/ok1a9jyfRYw.swf[/flash]
Post Posted: Sun Aug 14, 2011 2:34 am
Shithot Atari, great find!!
That opens up lots of possibles for light mods.
Post Posted: Sun Aug 14, 2011 2:40 am
it's an old trick from wayback, just remember the temp difference between Fahrenheit & Degrees.... would be piss funny to see it do the shrinky dink trick or turned to melted cheese. :lol:
Post Posted: Mon Aug 15, 2011 5:16 am
Thanks so much guys.
Been so handy. I have a friend who owns Maitland Smash so i will see if i can get some fine graded paper so i can crack into it.
Atleast now we have a quick and easy title for headlight rejuvenation.
Mitch.
Vehicle: Jeep
Post Posted: Sat Aug 20, 2011 6:43 am
I just went to Auto One, to see if they had anything to restore headlight lenses...
They had stuff called, " Blue Magic " Headlight Lens Restorer for $13.56...
It says on the bottle, " Some lenses may require 3 or 4 applications, or for heavy yellowing, a light sanding with 2000 grit sandpaper first ", i think its a cutting compound of some sort, but it has something in it to prevent re-yellowing of the lens... at $13 a bottle, its worth a try, so i got some ! :wink:
Post Posted: Sat Aug 20, 2011 12:32 pm
DIY projectors, take a bit to get it right bit could be an option. http://forum.ih8mud.com/100-series-crui ... eries.html
Post Posted: Sun Aug 21, 2011 11:17 pm
Thanks for that link Atari great stuff
Do they handle of road jolts and vibrations alright?
Post Posted: Mon Aug 22, 2011 12:27 am
not sure sky, looking at the 100 series in that link i think they are all mall cruisers. :wink:
Post Posted: Mon Dec 05, 2011 9:28 pm
Sorry to dig up this thread, figured since you asked I would give you my opinions after running the Mini H1's for several months. This thread is link backed to mine (the mall cruiser 100 series guys). I have had no vibration issues since installing them. I haven't had any issues with alignment due to the added weight of the projector. I would not hesitate to put them in again. Great stuff. (not saying it because I work for them, it's the truth)
atari4x4- if we ever run across each other in the future. I will show you how the 100 Series guys wheel. :)
For the rest: Please let me know if I can help with anything, opening up your headlights can be a scary task, washing them can be catastrophic. I use water and dab lightly. Don't rub or use high pressure.
Nick
Users browsing this forum: Google Adsense [Bot] and 116 guests
