It is currently Sat Nov 07, 2026 12:28 am
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2
Post Posted: Wed Aug 17, 2011 8:52 am
Swampers, many 16" tyres like 7.50's, "proper" treps (i.e the comp treps, sadly only 37" and 40") Creepy crawlers, 'pedes, JT2's, Claws (eurgh) silverstones... there's plenty of bias/crossply off road tyres.
For good reason. Everything that makes radial better on road makes it worse off road.
Post Posted: Wed Aug 17, 2011 9:52 am
yep, my vote is the 32/9.5 swampers
Post Posted: Wed Aug 17, 2011 10:29 am
Want mine? I want bigger....
TWIN LOCK IT & JUST DRIVE!
Post Posted: Wed Aug 17, 2011 7:36 pm
I reckon 32X9 swampers are a bit small. 9X34's aren't much more hassle to fit but are a much more useful size.
Post Posted: Wed Aug 17, 2011 9:25 pm
How do swampers go on rock and clay
I wonder how hard it would be to cut the door jam on a vit to get them in with out a body lift
Post Posted: Wed Aug 17, 2011 10:35 pm
I've never had any reason to complain about the performance of my swampers on rock or clay.
There are better rubber compounds for rock, but the flexibility of the swamper carcass makes them hook up quite well. They are miles better than, say, a 'pede, and that's due to the very stiff carcass of the 'pede. Likewise, the tread is so much more flexible than a radial they can hook up where a radial will bounce off.
As for clay, they don't bite as well as a 'pede, but they aren't far behind. Again, the superior off road performance in other terrains and size availability of the swamper make them more attractive even when they won't quite match a 'pede on slick clay.
In deep clay there isn't really a tyre that works, it's more about tyre size and throttle IMHO.
Post Posted: Thu Aug 18, 2011 10:45 am
surely a gaurd lift/chop is required for swamper 34's. They measure a tad over 34 when new
Vehicle: Sierra Ute '87 Sj70
Post Posted: Thu Aug 18, 2011 10:15 pm
How much?
and info?
It's all coming together Armsup
Vehicle: Sj70 tintop
Post Posted: Thu Aug 18, 2011 10:21 pm
if a manufacturer released a 31x9 0r 7.... i would purchase it, but 32'' is a bit big, i would like a skinny 31'' for the optical illusion of it being a smaller tire.
Sj70 tintop
Vehicle: yellow 83 sierra
Post Posted: Thu Aug 18, 2011 11:32 pm
im looking for something nice and beefy for my sierra in a 235 75 15 i just need that bit more aggressive pattern abit better than my stock toyo A/Ts which go pretty well on it. any suggestions for the 235 75 15 muddies or even better comp tyres?
Post Posted: Thu Aug 18, 2011 11:43 pm
your not gonna get a comp spec tyre under 37 inches.
Vehicle: Zookless
Post Posted: Fri Aug 19, 2011 12:04 am
Federal Couragia MT are pretty chunky in a 235 75 R15. I'm really happy with mine.
The smallest "comp style" tyre you'll find is a Silverstone Extreme in a 31".
Post Posted: Fri Aug 19, 2011 12:06 am
depends on the comp, i wouldnt choose an ET for anything other than mud bogging,
Id rather a 650 - 16 creepie crawlie.
Vehicle: 2018 DMAX
Post Posted: Fri Aug 19, 2011 12:09 am
You can get a swamper TSL in a 29x8.50-15LT... There not available in Aus though, and not easy to get from the states either... Slightly bigger than a 235/75-15..
And ETs can be had in a 29.. But as tanshi said, no good for anything other than mud...
Users browsing this forum: Google [Bot] and 83 guests
