| Author |
Message |
Marksy_06
Joined: Mon May 12, 2008 11:30 pm Posts: 263 Location: Rawson, Vic
 Posted: Fri Nov 07, 2008 4:22 pm |
has any one got any idea what i can muck around with to fix my rear lights and horn so they work ? i have no wiring experience. but when my spotlights failed i managed to fix them by fiddling with the relay ect. does anyone know if reverse lights and horn would go through the relay ? maybe that just needs a new one ? i also had a look at the wires under the glove box and theres a red wire with nothing to connect to and a thick white connecter which also has nothing to connect with
royce
 Posted: Fri Nov 07, 2008 6:46 pm |
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Fri Nov 07, 2008 6:49 pm |
Checked fuses?
If the horn and reverse lights went through the same relay then they would both operate at the same time.
The wires under the dash could be for extras like aircon or something...
Get a test pencil and check things like whether the light relay has power to it, and whether the power is leaving it too.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Fri Nov 07, 2008 7:05 pm |
And check earths!!!
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Fri Nov 07, 2008 7:18 pm |
ScrawnC wrote: And check earths!!!
yer, if i ever have a problem with electesticals it's always a bad earth, usually coz all the surfaces have rusted a bit.
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Fri Nov 07, 2008 8:41 pm |
steve wrote: ScrawnC wrote: And check earths!!!  yer, if i ever have a problem with electesticals it's always a bad earth, usually coz all the surfaces have rusted a bit.
You have rusty electesticals
Scrawny
 Posted: Fri Nov 07, 2008 8:59 pm |
just_cruizin wrote: You have rusty electesticals
Can you get cream for that?
steve
Vehicle: 75 Cruiser
 Posted: Fri Nov 07, 2008 9:14 pm |
if you separate the surfaces and use a wire brush on the grinder it'll clean up real nice.
just_cruizin
 Posted: Fri Nov 07, 2008 9:40 pm |
Scrawny
 Posted: Fri Nov 07, 2008 10:45 pm |
Marksy_06
 Posted: Fri Nov 07, 2008 11:41 pm |
thanks guys ill try some of them things tomorrow. the horn works sometimes does that help narrow out the problem ?
lump_a_charcoal
 Posted: Sat Nov 08, 2008 12:00 am |
Pull the centre off the steering wheel, then make sure the contact points are nice and shiny. A fine file or emery cloth will help.
Scrawny
 Posted: Sat Nov 08, 2008 12:02 am |
Horn will have a bad contact. If you take the button off the wheel you may find the contacts are dirty or mis-aligned
Argh... beat me by >...< much Lumpy
lump_a_charcoal
 Posted: Sat Nov 08, 2008 12:06 am |
Bear
Joined: Fri Jun 20, 2008 11:30 pm Posts: 84 Location: Somewhere round the
 Posted: Sun Nov 09, 2008 5:48 am |
horn full of water and blown bulbs in lights?
Marksy_06
 Posted: Fri Jan 02, 2009 10:36 pm |
update! horn works when it wants too and i pulled out the reverse switch and sprayed contact cleaner on it and the connector to the power etc. and they worked but once i took it out and put it back into reverse they dont work again and the same spraying method doesnt work would this mean its defiantly the switch ?
