| Author |
Message |
toastysteve
Joined: Tue Feb 16, 2010 10:30 pm Posts: 112 Location: Brisbane (Northside)
Vehicle: SJ413 WT
 Posted: Sun Aug 21, 2011 12:25 pm |
Hi lads,
I'm scratching my head here trying to work out how the soft top sits over the top of the windscreen. I've got it clipped on, on both sides, but that's about all that's holding it in place.
I've got some soft rubber that sits on the top of the windscreen and a hard piece of plastic that the plastic strip on the softtop slips into... But that's just sitting loosely.
I've tried removing the soft rubber and sliding the hard plastic strip (with the soft top plastic strip already in place) onto the windscreen, but it won't sit and keeps popping up.
Any help, or pictures would be greatly appreciated.
Cheers,
toastysteve
Vehicle: SJ413 WT
 Posted: Sun Aug 21, 2011 1:08 pm |
Here's the instructions I'm following.
http://www.lowrangeoffroad.com/images/51361.pdf
I can complete all the steps, except step 1.
"Center the plastic strip and slip only the plastic into the
channel along the top of the windshield."
What channel? :S
Santos
Joined: Tue Jun 09, 2009 11:30 pm Posts: 1009 Location: Sydney -ish
Vehicle: 92 Suzuki Sierra
 Posted: Sun Aug 21, 2011 1:28 pm |
you should have a plastic strip running along the top of your windscreen from one stud to the other. maybe it missing?
_________________ -Santos
toastysteve
Vehicle: SJ413 WT
 Posted: Sun Aug 21, 2011 2:48 pm |
If it's hard plastic, then yeah I have it.
Is it meant to be attached? Because it comes right off for me....
OMG is it's meant to be glued on, isn't it... Then the plastic part of the soft top sits inside of it. Is that right?
But then where does the weather stripping (soft rubber) go?
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sun Aug 21, 2011 6:37 pm |
On the soft top there is a hard plastic strip that slides in sideways into a metal channel on the top of the windscreen. No glue at all.
_________________ mlm
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Sun Aug 21, 2011 6:59 pm |
Does your Sierra have the metal channel? Where abouts on the northside are you? I could have a look if you like? PM me if you would like a hand
_________________ Shep is a closet jimny lover!!!!
toastysteve
Vehicle: SJ413 WT
 Posted: Sun Aug 21, 2011 10:31 pm |
SierraDan wrote: On the soft top there is a hard plastic strip that slides in sideways into a metal channel on the top of the windscreen. No glue at all. Hi mate, thanks for the help. I've got the hard plastic strip on the soft top, but unless I'm missing something incredibly obvious here, I don't have a metal channel on the windscreen panel in which to attach it. Rusho wrote: Does your Sierra have the metal channel? Where abouts on the northside are you? I could have a look if you like? PM me if you would like a hand
No, I don't believe so. Cheers mate, I might take you up on that offer. I'll take some photos first and put em up tonight. Hopefully it'll be obvious to everyone what I've done wrong. :S
I've been looking for examples online, but can't see a single up close shot of the windscreen anywhere.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sun Aug 21, 2011 10:59 pm |
The 15mm or so strip attached to the front of the soft top slides inside a plastic C channel piece that is screwed to the top of the windscreen frame just in front of the rubber. Check the top of your frame and you'll probably see several small screw holes.
I have a few here if you can't find one closer.
toastysteve
Vehicle: SJ413 WT
 Posted: Sun Aug 21, 2011 11:56 pm |
want33s wrote: Check the top of your frame and you'll probably see several small screw holes.
Ahhh that makes sense then.
The frame doesn't seem to have any screw holes, but the plastic C channel piece DOES.
So it's actually plastic, not metal then?
I guess I can just drill some holes through the panel and attach it then.
Rusho
 Posted: Mon Aug 22, 2011 1:55 am |
Put some pics up before you go drilling anything....just in case
toastysteve
Vehicle: SJ413 WT
 Posted: Mon Aug 22, 2011 2:01 am |
Hahaha what're you talking about? When has the 'shoot first, ask questions later' method ever failed?
Rusho
 Posted: Mon Aug 22, 2011 2:20 am |
BlueSuzy
 Posted: Mon Aug 22, 2011 2:29 am |
The channel is plastic. It screws to the metal window frame.
toastysteve
Vehicle: SJ413 WT
 Posted: Mon Aug 22, 2011 7:49 am |
Ok so here's the plastic c channel you were talking about....
It has holes already drilled in it.
And here's the windscreen panel...
I'm guessing I should be drilling downwards into the panel?
Like... so -
toastysteve
Vehicle: SJ413 WT
 Posted: Mon Aug 22, 2011 7:53 am |
Plz excuse all the mud everywhere... Epic 4wd adventures had on the weekend.
Rusho
 Posted: Mon Aug 22, 2011 8:15 am |
Spot on mate
toastysteve
Vehicle: SJ413 WT
 Posted: Mon Aug 22, 2011 12:25 pm |
Big win.
Thanks very much guys.
Looks schmick!
