It is currently Mon Aug 03, 2026 9:54 am
Post Posted: Mon Aug 22, 2011 4:45 am
trying to drill through 5mm flat bar and dulled my drill bit.
I dont have a fancy bench drill. Is there a certain brand/sort of drill bit i should be buying i dont want to spend to much as i probly wont use it again if ever
Ricky
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Mon Aug 22, 2011 4:48 am
Sutton, slow the drill down a bit and push harder, will rip right through
Vehicle: On the lookout
Post Posted: Mon Aug 22, 2011 4:50 am
I used a $18 Ten pack of bits to drill holes up to 10mm through 5mm steel at the weekend with a cheap hand held drill. Was easy. I predict the bits will drill about 5-7 holes before they are blunt at the rate I was getting through them. You don't have to spend a lot of money.
Crispy old grand vitara
Vehicle: '96 LWB trayback
Post Posted: Mon Aug 22, 2011 4:54 am
Sutton drill bits all the way. how big a hole are you drilling?
I'm drilling loads of 8-10mm holes in 10mm flat bar lately.
Just using a scummy old hand drill and sutton high speed drill bits.
Start with a 3mm pilot hole and step up a couple of times. 3-5-8-10mm.
Only takes like 60 seconds, and the drillbits are still razor sharp after about 30 holes drilled.
Post Posted: Mon Aug 22, 2011 4:56 am
Good quality drill bit is gonna last alot more than 5 holes
Post Posted: Mon Aug 22, 2011 5:16 am
10mm holes i had drill on flat stick and was pressing down. will slow it down and source some sutton drill bits
thanks guys
Post Posted: Mon Aug 22, 2011 5:31 am
A bit of cutting oil will help too. The last thing you want to do is go flat out when drilling. As soon as the end of the drillbit gets hot, it looses its edge and bingo, blunt drill bit, more friction, more heat, ect ect.
If you don't have cutting oil, veggy oil will do or even water at a pinch, anything to lubricate and help the drill bit cut.
A 3mm pilot hole is all you should need for a 10mm hole.
Post Posted: Mon Aug 22, 2011 5:35 am
i got vegetable oil will give it a shot on wednesday. thanks for the advice guys.
Vehicle: Daisy
Post Posted: Mon Aug 22, 2011 6:12 am
Even engine oil will do, you could even use water to keep it cool if you were desperate (or drilling ally, water is boss when drilling/cutting ally)
Just don't overheat the tip and you will be fine!
Post Posted: Mon Aug 22, 2011 6:55 am
you can also do it with squirts of the drill.
1 second bursts with lots of pressure.
if you do burn out your drill bit dont keep going, stop and sharpen it or get a new bit.
Post Posted: Mon Aug 22, 2011 7:24 am
dont know how to sharpen a drill bit so thats not an option
Post Posted: Mon Aug 22, 2011 7:32 am
Just grind the bit on the same angles as it already is. Keep quenching the bit in water to keep it cool and sharpen it before it goes blue.
Post Posted: Mon Aug 22, 2011 7:35 am
Stepping it up in small incriments as above can be just as bad for the drill bit.
Pilot hole with a 30bit.
Then 10mm straight through afterwards. Drill slowly with a firm hand and you wont have a drama. Even with a cheap drill bit. At work I can literally do 30-40holes a day like this if not more and a bit lasts a couple of weeks. Spinning it up fast heats it up, and will dull the bit as quick as you can blink and you will be there for days.
Post Posted: Mon Aug 22, 2011 8:23 am
http://www.ebay.com.au/itm/Drill-doctor ... 4aa3b69d69
I have one of these puppies cause I'm lazy :D Its not very difficult to sharpen a drill bit on a grinder but these things make it a breeze.
Post Posted: Mon Aug 22, 2011 8:32 am
slow drill speed and cutting oil is the ticket and bits will last forever.
suttons and p&n have always been good to me.
and a drill press always helps :wink:
Post Posted: Mon Aug 22, 2011 8:57 am
dont drill enough holes to need a press but would be very hand right now.
ill buy a new drill bit
slow the drill speed down
and use some oil
should be all sweet.
Post Posted: Mon Aug 22, 2011 10:13 am
http://www.dewalt.com.au/accessories/pr ... archy/128/
i use these im a mobile site welder im getting 50+ 1/2 holes out of each bit cost about $14 each the trick is keep a firm pressure when drilling or you lose the temper and then its ruined and control the speed lube is a must if doing more than 4 holes one after the other
Post Posted: Mon Aug 22, 2011 6:55 pm
+1
While a pilot is not necessary for holes under 1/2" in a drill press, a small pilot is a help when using a hand drill. Even drilling 1-1/2" holes at work the other day was only a 2 step increase, 1/2" pilot then straight to 1-1/2"". Auto feed radial drill makes it a bit easier tho :D .
Its keeping a constant firm pressure on the bit thats the trick with a hand drill. Let the pressure off and the drill rubs instead of cuts, cooks, and thats the end of it. Keep the drill speed correct (can be hard with a hand drill), too slow on a small drill is as bad as too fast on a big drill .
Lanotec (lanolin) is a pretty handy cutting fluid when using a hand drill.
Post Posted: Tue Aug 23, 2011 11:08 am
That is bucketload of stupid questions, not cash!
Post Posted: Tue Aug 23, 2011 12:56 pm
<flame suit on>
sutton and p&n used to be good, but unless you get their premium range, which is still made in oz, arent all that great.
<flame suit off>
all the cool kids are using dormer or bordo.....at half the price :wink:
Go Hard, Trailer Home
Users browsing this forum: No registered users and 1206 guests
