It is currently Sat Nov 07, 2026 12:12 pm
Post Posted: Mon Aug 22, 2011 9:47 pm
I have installed a g16a into my 89 Sierra
I have just started wiring it up and I am trying to figure out what to do with the plug that comes off the carby as they are different
I have searched but havnt found any relevant info
If you have any links or knowledge it would be appreciated
Thanks in advance
F#%ING [P] PLATER
 Profile YIM
Post Posted: Mon Aug 22, 2011 9:49 pm
I am also having trouble finding where this plug goes
F#%ING [P] PLATER
 Profile YIM
Post Posted: Tue Aug 23, 2011 11:58 am
I did this one about a month ago. On the Sierra there is a ground, a power wire when the ignition is on and i think an idle up wire. The 16a needs power when the ignition is on for the idle cutoff solenoid(the small one to the rear) and the bowl vent(larger on on the front). Just trace the wires from the solidoids and connect them to the ignition wire. The 16a also has a microswitch on the throttle that closes at idle, I think the normal arrangment has the idle cutoff solenoid operated by this.
Users browsing this forum: No registered users and 79 guests
