heyy guys, i just went out and got myself a 1993 suzuki sierra and was just wondering about a few things that use might be able to help me with.
first off all the headlights on it don't seem to be working i have checked all the wiring and stuff and im not to sure on what it is, would anyone be able to help??
another thing is that i have 31x10.5x15", and when i turn the wheels they attend to scrub on the inner of the guards. The guy that i got it off told me that it had a 2inch lift on it but im not to sure if it does or not :/
Joined: Sun Jun 28, 2009 11:30 pm Posts: 170 Location: Wangaratta, Vic
Posted: Sat Sep 03, 2011 11:19 pm
Did you check the fuses and globes for the headlights?
I know its uncommon to blow 2 globes at once but if you have water in the headlights and turn them on it will shatter the globes, so it can happen.
If there all good get a multi meter or test light. One pin on the plug should have power (to ground) all the time, then the other 2 switch to ground through the light switch.
With the wheels have a look at where it scrubs and you might be able to bash it back abit with a hammer. 31s sound abit big for only a 2inch lift, mines got over 4inch of lift and runs 31s just nice. Also if its a spring lift they will tend to sag after a while.
Users browsing this forum: No registered users and 60 guests
