It is currently Sat Nov 07, 2026 1:46 pm
Vehicle: 89 vitara
Post Posted: Sun Sep 11, 2011 9:18 am
hey guys looking at getting the lockas in the rear on my 89 swb vitara. proble from low range, my question is, do i need the couplers or not? do i need to know the spline size? nstupid questions but i have no idea on this one.
any other places i should look at?
cheers jordan
Post Posted: Sun Sep 11, 2011 9:23 am
Hi Sicktara
There are a number of threads on your question in the tech section
cheers
martin
Vehicle: 89 vitara
Post Posted: Sun Sep 11, 2011 9:33 am
i cant find them :/ still getting use to this site
Post Posted: Sun Sep 11, 2011 9:40 am
http://www.auszookers.com/index.php?nam ... locker+vit
try this, it might help
Post Posted: Sun Sep 11, 2011 10:18 am
Order yourseld a 1510 lockright. its the same as the 1512 but comes with sierra cross pins that you wont need.
Post Posted: Mon Sep 12, 2011 8:32 am
I can not remember which, but I have heard rumor one engages and disengages better than the other.
I can not remember if it is the one that comes with the couplers, or the one that re-uses your side gears.
I am sure someone will come along and tell us which is better (if it is not just all in the setup).
I am not 100% but I believe your front diff will have 22 spline side gears and axles, the rear will always be 26 spline.
You may want to look for a steel front diff when you can. They hold up better than the ally ones.
Post Posted: Mon Sep 12, 2011 9:18 am
the one with couplers is really hard on the driveline. Best to use the 1510 that uses your side gears.
Post Posted: Mon Sep 12, 2011 10:39 am
Im going through this at the moment aswell.
Did some googling and found that using the stock side gears allows a smoother locking/unlocking, compared to using the couplers which are more agressive
My Grand Vitara
Post Posted: Mon Sep 12, 2011 11:14 am
x2, i run the one without the couplings, just make sure you get someone decent to install it for you. will decide whether your car will stay a pleasure to drive or become a pig to drive.
Post Posted: Mon Sep 12, 2011 11:21 am
would 1510 work in a lwb too?
Every problem can be solved with a Ratchet.
Post Posted: Mon Sep 12, 2011 11:27 am
cant see why it wouldnt, its the same differential. but im sure some one will correct me.
Vehicle: 89 vitara
Post Posted: Tue Sep 13, 2011 8:44 am
so just orderthe 1510?
Post Posted: Tue Sep 13, 2011 1:29 pm
i dont want to be the one to make the decision for you but yeah. have a look on the lowrange offroad (i think) website and choose your model vit, then choose the locker WITHOUT couplers.
enjoy
Users browsing this forum: Google [Bot] and 82 guests
