It is currently Sun Aug 02, 2026 2:51 pm
Post Posted: Mon Sep 05, 2011 8:12 am
Hiya guru's,
I have a GV and experienced a weird thing whilst driving today. The handbrake warning light came on whilst actually driving. I made sure the handbrake was off but the light stayed on. Stopped at the lights I pulled the handbrake and the light got brighter.
I know one of the uses of the handbrake light is to signal there's low brake fluid. Once I pulled over I checked the fluid and it was fine.
Once I turned the engine back on the light operated as normal.
Looking through the FSM I can't find if the light warns of anything else? Does it?
Am I missing something??? Could it just be a random bad earth? Where could it be?
Thanks.
2002 SWB GV
Lifted and Locked
Post Posted: Mon Sep 05, 2011 8:26 am
Sounds like it may just be low brake fluid level.
Post Posted: Mon Sep 05, 2011 8:27 am
search noob, it's been covered thousands of times before. 2 can play your game.... :helloo:
could be the handbrake switch under the centre console is getting lazy/gummed up.
Post Posted: Mon Sep 05, 2011 8:36 am
I checked the fluid level on the side of the road and it was fine.
2002 SWB GV
Lifted and Locked
Post Posted: Mon Sep 05, 2011 8:37 am
Smartarse :finger:
2002 SWB GV
Lifted and Locked
Post Posted: Mon Sep 05, 2011 8:42 am
Smartarse :finger:
so did you search before posting?
what were your keywords when searching?
did you refine that search by selecting suzuki talk?
:thefinger:
Post Posted: Mon Sep 05, 2011 8:58 am
Yep, searched. Only issues that came up are low brake fluid and bad handbrake switch.
I did test the handbrake switch and I can only make the light turn on when I pull the handbrake up to the first click, which is about pulling it 30-40mm.
2002 SWB GV
Lifted and Locked
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Sep 05, 2011 9:04 am
A coin hasn't slipped in and shorted the circuit? I've had that happen before
Post Posted: Mon Sep 05, 2011 9:24 am
Mines been doing this crap for a long time, even too the switch out and it works, then you put the casing back, go for a drive and bam, back again.
Post Posted: Mon Sep 05, 2011 10:13 am
The switch earths, so the console could be pushing the wire to earth some place..
Post Posted: Mon Sep 05, 2011 10:14 am
Or the floats gummed up with shit.
Post Posted: Wed Sep 07, 2011 10:09 am
The light goes off but comes back on when you start the motor, im guessing it must be gummed up with shit then. How do you tackle this problemo.
Vehicle: G16b Sj80, Version 6 GC8 STi
Post Posted: Wed Sep 07, 2011 10:33 am
My handbreak light (!) Comes on every time my car leans heavily around a corner... Its almost like a warning light telling me that I shouldn't be cornering so hard in a sierra :lol:
Subi + Suzi = Best of both worlds!
Post Posted: Wed Sep 07, 2011 7:21 pm
THAT is an indication of low fluid level - you turn, the car leans, the fluid sloshes to one side, the light comes on - give it a little more time and the level will drop enough for the light to come on & stay on.
Post Posted: Tue Sep 13, 2011 11:12 am
Is this the low brake fluid sensor cable?
The handbrake light came on again when driving and only turning the engine off/on turned the light off. Working the handbrake didn't do anything.
As an experiment I disconnected the sensor wire (well I think it's low brake fluid sensor wire) but the handbrake light didn't come on. I thought it would've though, or am I missing something? (the engine was running)
2002 SWB GV
Lifted and Locked
Post Posted: Wed Sep 14, 2011 7:22 am
If that fixes it, i'm just gonna disconnect the sensor wire.
Post Posted: Mon Oct 31, 2011 9:42 pm
Just a little update on my situation.
I have diconnected the brake fluid switch for a couple of weeks. Result is the brake warning light comes on intermittantly. So that rules the brake fluid switch out. I reconnected the switch.
I disconnected the handbrake switch for a week or so. Result is the brake warning light comes on intermittantly. So that rules the handbrake switch out as well.
However the light comes on only on startup. When I turn the engine OFF and restart the light turns off.
As far as I can tell only these 2 switches trigger the brake warning light. I don't have ABS.
Any other ideas? The FSM said if neither of these 2 cause the fault then replace the Combination Meter (ie the instrument cluster), WTF???
I'm not sure where there could possibly be a bad earth...???
2002 SWB GV
Lifted and Locked
Post Posted: Mon Oct 31, 2011 10:10 pm
The wire from the handbrake switch runs along the trsnsmission tunnel, right alongside the #2 shifter boot on the 5 speed (the one that screws to the transmission tunnel) - if you remove the boot for any reason (to drop the transmission whilst replacing the clutch, etc.) it's fairly easy to pinch the wire when replacing the boot - and fairly difficult to find because it's under the carpet, under the console.
Vehicle: 1999 Jimny hardtop G13BB
Post Posted: Thu Mar 21, 2013 9:58 pm
not sure if you're still chasing the fault. i has a similar problem in my jimny, handbrake light would come on when it was started.
tracked it down to the key switch. wriggling the key after starting made the light go out. One of the contacts was worn enough that it wasn't returning to the on position.
Post Posted: Fri Mar 22, 2013 5:13 am
Yeah I still have the problem, just not as frequent. I'll try wriggling the key. Cheers.
Post Posted: Tue Apr 16, 2013 4:27 pm
Follow up.
My problem seems to be with the key switch. Thanks for the tip Nate.
I guess the switch is getting a bit worn with my other keys hanging off it.
Users browsing this forum: No registered users and 187 guests
