It is currently Tue Aug 04, 2026 7:23 am
Post Posted: Wed Sep 14, 2011 7:16 am
hey guys i am about to start a lwb build. i have almost everything except the rear drive shaft now my question is would it be easier to get one extended or use a shaft out of something else
Post Posted: Wed Sep 14, 2011 7:45 am
i would say find a Drive shaft out of something else or get custom one made thats what i would do
Post Posted: Wed Sep 14, 2011 7:47 am
yea i have heard that people use hilux shafts but i'm not sure if it still has to be modded
Post Posted: Wed Sep 14, 2011 7:52 am
Yep. Rear section of a hilux 4wd 2 piece shaft from a 88-97 model. It is shorter than a sierra SWB rear shaft, so you'll need to get it re-tubed.
Benifits are.....
Bigger ( stronger ) tube
Longer spline
MUCH bigger ( and there for stronger ) Uni joints
WT bolt pattern.
You will however, have to remove your pinion and transfer case flanges to have the centre bore opened up 1mm to accept the slightly larger hilux locating spigot. Get this done when you have the shaft lengthened.
Post Posted: Wed Sep 14, 2011 7:55 am
is it safe to use on road with it lengthened since i would like to be able to drive it on road
Post Posted: Wed Sep 14, 2011 8:04 am
:? Yeah mate..... :? Why wouldn't it be??? :crazy:
Post Posted: Wed Sep 14, 2011 8:08 am
i dunno i have never had any experience with drive shaft so i wouldn't know
Post Posted: Wed Sep 14, 2011 8:17 am
Safe as mate, but take it to a good shaft shop.
I have heard of people in the past using exhaust pipe for shaft's, not recommended, but it worked for that application..
Post Posted: Wed Sep 14, 2011 8:27 am
okay well thanks for the help i will put a build thread up when i start
Post Posted: Wed Sep 14, 2011 8:32 am
It's on the interweb's now, so you have to :wink:
Post Posted: Wed Sep 14, 2011 8:38 am
well i will but at the moment its only a bare chassis so really not worth it
Users browsing this forum: Google [Bot] and 270 guests
