It is currently Sat Nov 07, 2026 1:54 pm
Post Posted: Wed Sep 14, 2011 12:33 pm
I was just wondering if anyone has made roof racks for their soft top or fibre glass top vitara. You can buy the calmini one but has any one made their own?
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Post Posted: Wed Sep 14, 2011 12:50 pm
CJ had one made. Its a bit low rent IMO ( finish and structure) but he says its pretty strong.
Vehicle: Coily.
Post Posted: Wed Sep 14, 2011 11:52 pm
I stopped a Sierra on the Gold Coast a few Months ago to enquire on his roof rack,he had a Glass top and a Holden VN/VP Wagon factory black rack just bolted on. Ok for light loads apparently so i got one off a wrecker for $50 and just working up the courage to bore holes in the Fibreglass canopy to fit it.
Regards All from far Northern NSW.
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Thu Sep 15, 2011 12:01 am
I looked at getting one made, but it was going to work out more expensive than the Calmini one, so i just bought that. It's strong and well made.
I am welding some mesh to the floor of the basket this week hopefully so that will make it even stronger again.
Bunnings has galvanised reinforcing mesh in the garden section, 75x50mm squares at 4mm diameter for $44. It's 2x1.2m so plenty big enough. Will get the lot re-powder coated once it's all welded up.
Only annoying thing was as it's American all the nuts/bots were imperial and I only have metric tools!
Vehicle: Suzuki Grand Vitata 2018
Post Posted: Thu Sep 15, 2011 1:07 am
like this one?
outdoors
Post Posted: Thu Sep 15, 2011 1:11 am
Marked wrote:
like this one?
outdoors
Thats the one. It looks to be made by the same 'fabricator' as the-ninja-kid's barwork on his SV420.
For $450 its not bad value, but most of the welds have been ground back smooth. A poor welder makes a great grinder :wink:
Post Posted: Thu Sep 15, 2011 1:28 am
^^^ i've seen hills hoists with lower profiles than that. 8O
Post Posted: Thu Sep 15, 2011 1:44 am
Yeah it could have been a little lower. But spending the time doing that would drive the price up.
Post Posted: Thu Sep 15, 2011 5:51 am
Cheaper than the Calmini, but from what I could see the Calmini seemed a bit better built, sat lower and included a basket with 4 spotlight mounts.
Post Posted: Thu Sep 15, 2011 5:57 am
Bingo :wink:
Post Posted: Thu Sep 15, 2011 8:09 am
Ain't that the fruggin truth. (As Sky wipes the grinder dust from his face, and shakes metal out of his hair and ears) armsup
Looking at the options, couldn't one be adapted from another vehicle, or a generic one be used? If I could not weld, I think I would rather fabricate one from materials I could rivet or screw than use the one pictured above.
Vehicle: Vitara 90'
Post Posted: Fri Sep 16, 2011 2:54 am
Disclaimer: Not the best idea and I wouldn't do it but....
If you just made a short one that you could bolt to the top of the windscreen and then above the B pillar that could work but you couldn't carry much more than a body, 2 at the absolute most. ;)
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 68 guests
