It is currently Tue Aug 04, 2026 2:46 am
Post Posted: Thu Sep 15, 2011 8:27 am
hi guys. looking at supercharging my sierra with something like a sc12. has 1.6 efi vitara motor. just wondering how much boost i could run before i upgrade my ecu. does the AFM adjust the fuel air ratio and whats the highest boost you can run before upgrading ecu?? also when upgrading the ecu you can remove the AFM?
Post Posted: Thu Sep 15, 2011 8:50 am
umm... lets see... you can run Nothing :) Unless you want to lean out your motor and watch it burn in the fiery pits of hell :)
Well from my research thats what i've found anyway :)
if your going to go to the extent of Turbo'ing or Supercharging your Sierra, do it once and do it properly, get an ECU, Wire it in, and get it tuned right :)
Thats just my opinion
Stocker
Post Posted: Thu Sep 15, 2011 8:54 am
ave a look around in the threads for stuff on a Megasquirt. In my personal opinion, with the low cost of putting a megasquirt on an engine today one would have to be a retard to try and "squeeze" what they could out of the factory ECU. You'd just be pissing your time, and in all likelyhood money, against the wall.
Post Posted: Thu Sep 15, 2011 8:56 am
so a megasquirt can adjust fuel air ratios?
Oh yeah, and get the programmable ECU running well on the un-modified engine first then go forced induction. That way you're minimizing the number of changes at any one time and drastically reducing the risk of the project becoming a right PITA.
Post Posted: Thu Sep 15, 2011 8:57 am
A megasquirt is an open-source EFI computer. Completely replaces your current computer...
Post Posted: Thu Sep 15, 2011 9:05 am
damn. sounding a bit full on lol. thought it would be a good idea to get some more poke out of the engine as were i live i drive massive sandhills and need a bit more power.
Post Posted: Thu Sep 15, 2011 9:12 am
What sought Tyre sizes vs Diff ratio's are you running?
Stocker
Post Posted: Thu Sep 15, 2011 9:16 am
31x10.50 15
standard w/t
standard transfer
looking at reduction gears as we speak =)
Vehicle: 85 hightop drover
Post Posted: Thu Sep 15, 2011 9:42 am
Tyres to big for those gears, I have n/t (which
Have lower diff ratios) with the 16valve I run 29"s
And I can't find a dune it won't go up!
16valve efi hightop drover
Post Posted: Thu Sep 15, 2011 12:43 pm
Seriously did you really think you could just 'bung on' a supercharger and away she goes?
A rising rate FPR with the stock ECU can be made to work but unless you have a spare engine on standby it really is a dodgy band-aid compromise. Plus teh fact that these G motors are not really the strongest things out there.
Here's a 'cheap' turbo setup on a 1.6 that has been made to work to give you an idea.
http://bbs.zuwharrie.com/content?topic=85570.0
Lil Foot!
Post Posted: Thu Sep 15, 2011 11:15 pm
I've done some reading. So I have no experience at all on this. But I've read that the sc12 is very old and not made by Toyota anymore and also very hard to get parts for.
Let me know how you go though, because I'd love to boost mine. :)
Post Posted: Thu Sep 15, 2011 11:28 pm
Hey guys.....look at it this way.
Unless you already know what you are doing ( and I mean down to the last nut and bolt ) with regards to install and more importantly, tuning; the money you save now by not running a piggy back or stand alone replacement ECU, and fuel system upgrades will be needed to replace your motor very soon after.
The G16B is not really suited to forced induction in standard trim. So anything short of a 'all bases covered' install will absolutely result in a search for a replacement motor.
Post Posted: Fri Sep 16, 2011 12:50 am
A motor every year isnt bad :p
Post Posted: Fri Sep 16, 2011 12:54 am
just do it, don't listen to the haters... make sure you keep us updated. :wink:
Post Posted: Fri Sep 16, 2011 1:39 am
1.6 EFI is stacks of grunt for a Sierra mate...
Your issue is not a lack of power, its a lack of gearing. Get some 4.9 gears or similar in the transfer and you'll be sweet as.
I want my old sig back :(
Post Posted: Fri Sep 16, 2011 1:41 am
no he needs boost, lots of boost... boost fixes everything. :P
Post Posted: Fri Sep 16, 2011 1:43 am
Oh thats right, 31's with no gearing and a blown 1.6 on a Sierra is a great setup. If you like changing clutches once a week :P
Post Posted: Fri Sep 16, 2011 5:05 am
Wont find a hater here :D
Daily I'm thinking of new and exciting plans to boost mine. There's nothing quite like that feeling when you've done a conversion yourself, and you take it out for the first time. Last time this happend with me was a datsun 1200, sideways in a straight line followed shortly by clutch failure 8O
Was a good time though...
Post Posted: Fri Sep 16, 2011 1:44 pm
ok not being either way but it has been done..
a certen red sierra got built, driven round Hobart, up to qld, across and back down with a g13bb (1300 version of the vitara basicly) super charger running 8psi and a rising rate... it is still owned buy auszookers member and still driven about.
Post Posted: Fri Sep 16, 2011 1:54 pm
:roll:
It is WELL documented that the GTI internals are substantially stronger than a vitara motor.
How about you compare apples with apples......
Post Posted: Fri Sep 16, 2011 2:04 pm
:roll:
did u read what i wrote???
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
Post Posted: Fri Sep 16, 2011 2:41 pm
i hope everyone is sitting down... :lol:
i'll back Phil on this one, i caught up with Simon on his epic mainland adventure & that little jigger was one of the only Sierra's that didn't struggle through the hills & on the open road, can't remember the number of km's he did on that trip but it would have to be near enough to 10,000kms & it was in Brenno's green LWB before that.
Post Posted: Fri Sep 16, 2011 9:17 pm
see what happens, you forget to answer one pm and he is ganging up with johnno against you fat 8O 8O :P
Post Posted: Fri Sep 16, 2011 11:05 pm
:rofl:
Users browsing this forum: Google [Bot] and 224 guests
