It is currently Sun Jul 19, 2026 2:56 pm
Post Posted: Tue Sep 20, 2011 2:46 am
Going to do the big order soon, thought I would see if anyone has these bits on here coz Suzistores prices are a bit out there. :crazy: I'm after new stuff here, except for the springs. :helloo:
This is all for an LJ81 Stockman. :wink:
Shifter bushes.
Gbox mounts (front)
Gbox seals+bearings. (where do you get the bearings?)
Unis. (x2 I think, I'l have to check)
Fuel pump kit. (should I even bother? Do these fail very often?)
Carby kit.
Brake master cyl kit.
Probably wheel cyl kits too, havn't got that far yet.
Water pump.
Timing belt.
Boots for the tie rod ends, Probably need a few tie rods too.
Swivel hub rebuild kit. (can all the bits from this be swapped over when I go to Sierra hubs?)
Bailey channels and door seals.
Springs and shockies both ends. (Anyone know what will fit the back of an 81 in terms of shocks from supercheap?)
The second hand stuff I need (or want). I'm looking for am LJ locally to rob some parts off, if I don't find one I'l get this stuff off you guys.
[rant]
I put a wanted ad up on the notice board in town (farming community, basically every farm has a Suzuki) and every number got taken off it and no one called! :cry:
[/rant]
Driver side guard. Strait and with a battery tray.
Bonnet. (not flown up and preferably with corners)
Stockman grill.
Lots of the plastic lights.
Steering box.
Tuning knob for the stereo. :lol:
That little plug thingy that goes on Gbox where you do the timing. :lol:
I'l add more stuff when I think of it. :wink:
3cyl, I'l get back to you about those axles when I have the money for them, $$$ has to go towards other stuff right now. :oops:
Hooki, it doesn't look like I'm going to Perth any time soon. I might be able to get a family friend to pick the stuff up this weekend though. I'l let you know what happens.
Thanks
Hayden
Post Posted: Thu Sep 22, 2011 3:15 pm
Bump. :wink:
Post Posted: Thu Sep 22, 2011 9:48 pm
Shifter bushes.
Gbox mounts (front) E-Bay
Gbox seals+bearings. (where do you get the bearings?) CBC used to do a complete bearing kit. LJ50/80/81 and early SJ40 are the same.
Unis. (x2 I think, I'l have to check)RUJ-1795. From bearing shop, auto parts shop or E-Bay
Fuel pump kit. (should I even bother? Do these fail very often?) Why bother? Wait 'til it's failed.
Carby kit.
Probably wheel cyl kits too, havn't got that far yet. E-Bay
Water pump. E-Bay
Timing belt.
Swivel hub rebuild kit. (can all the bits from this be swapped over when I go to Sierra hubs?) Same as Sierra.
Bailey channels and door seals. Overseas via LJ10.com
Springs and shockies both ends. (Anyone know what will fit the back of an 81 in terms of shocks from supercheap?) While the LJ80 has an odd rear shock, the LJ81 is a standard eye/eye shock the same as other Suzuki leafies. Use whatever Commodore/Hilux set up you would in a Sierra.
That little plug thingy that goes on Gbox where you do the timing. :lol: E-Bay
Thanks
Hayden
Vehicle: Suzuki LJ50 & LJ81
Post Posted: Fri Sep 23, 2011 12:04 am
The bailey channel can be bought from Clark Rubber. Not sure if they are in WA. The door seals which I am going to use on my LJ81 are called pinch weld. Ebay sells it the cheapest.
Post Posted: Sat Sep 24, 2011 4:15 pm
Thanks guys! I'l look into it!
With a pinch of luck, I found a heap of new bailey channel in the parts for my Pug 403, just gotta see of it'l fit! :helloo:
Users browsing this forum: No registered users and 66 guests
