It is currently Mon Nov 09, 2026 1:53 am
Post Posted: Tue Oct 04, 2011 7:24 am
hey guys I've searched around a bit and haven't found a whole lot
has anybody got any pictures or ideas for upgrading the mounting of the transfer case in a vitara. mine is rotating a lot with the reduction gears and bent the selector i can only assume on the tunnel and made me 2wdrive only for a little bit.
Post Posted: Tue Oct 04, 2011 7:35 am
Are you sure your Mounts aren't just old, the rubber does become very soft after a while.
Try replacing all the mounts (and probably engine mounts if your getting that much movement).
they all need to work in harmony to keep everything vibration free
Stocker
Post Posted: Tue Oct 04, 2011 7:45 am
mate ive smashed most of the mounts in the car in the last few years so none are two old didnt do it before gears and it was driven alot harder as you needed to as it wouldnt crawl
Post Posted: Tue Oct 04, 2011 7:58 am
have you found any flogged out mounts though?
anything that could cause excessive vibration which could cause the mounts to fail prematurely (shitty uni joints, etc...)
Stocker
Post Posted: Tue Oct 04, 2011 8:07 am
not really mate mounts are fairly new as i said uni's have been replaced diff is almost flat to the drive shaft everything seems good to me just the extra torque seems to be rotating the transfer doesnt need to move that much really to strike the tunnel. havnt seen it hit the tunnel but cant think what else would bend the selector all of a sudden while out 4wdriving. nothing can push my transfer unless its going thought a 5mm plate
Post Posted: Tue Oct 04, 2011 8:14 am
maybe a set of hydraulic bumpstops coupled to the gearbox with a stopper on the X-member???
Stocker
Post Posted: Tue Oct 04, 2011 8:22 am
look at the left eng mount
Post Posted: Tue Oct 04, 2011 8:23 am
been there replaced that looked at it looks fine but may have failed internally
Post Posted: Tue Oct 04, 2011 9:31 am
The torque astounded me after fitting gears,
it is hard to stop, (auto) even with 4 wheel discs.
I can see mounts becoming an issue.
I carry a spare, because vit came with one :)
Post Posted: Tue Oct 04, 2011 9:33 am
Maybe will need to tackle this myself in future,
I will share if I get any brainy ideas,
and I'll share dumb ideas, too :)
Post Posted: Wed Oct 05, 2011 6:54 am
mate the gears are awesome make the car soo much more driveable the extra torque you get is amazing and ive had a few dumb ones soo far so dont worry mate
Post Posted: Tue Feb 07, 2012 7:20 pm
hey guys, thinking about getting some gears as driving with 31's on std gears cant last to long. what did you do to over come the issue?
a shop in the us (could be LROR) have made some 'indestructible" mounts, has anyone used these or know of them? will try find a link.
cheers
Post Posted: Tue Feb 07, 2012 7:28 pm
I fitted unbreakable engine mounts from LROR,
(designed to fit the 1.6 into a Sierra, but I made them fit the Vit)
so far they seem to take the strain,
and stock t-case mount is doing well.
Being an auto could be less severe on them, too.
Users browsing this forum: No registered users and 124 guests
