It is currently Sat Nov 07, 2026 8:44 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Poll: Are you interested in a bolt of HD steering solution for your sierra?
Yes 73%  73%  [ 24 ]
No 6%  6%  [ 2 ]
I'll make my own 21%  21%  [ 7 ]
Total votes : 33
Vehicle: WR250F/Jeep XJ
Post Posted: Thu Oct 20, 2011 2:21 am
Hey guys, after pretzling my indian aftermarket tierod on the weekend doing some rock crawling no one except superior seem to supply a standard HD bolt on HD setup. At $750 for a superior unit I think it's out of reach for the average zook driver.
I have a supplier who is interested to make some heavy duty draglink/tierod combos that would bolt into the standard suzuki. Looking at only producing widetrack versions but if there is enough interest we could look at NT as well.
Please post here with your thoughts and also vote in the poll so i can get an idea of interest.
It's all in the interests of providing a good Heavy Duty product at an affordable price. At this stage some heavy wall mild steel pipe or mecaval are the options as i think CrMo is probably overkill in a zook and cost prohibitive.
Let me know your thoughts, would you buy one at the right price?
PS - this would include upgraded greasable tie rod ends most likely out of a 40 series as they have same taper i believe.
LIKE US ON FACEBOOK - KPD4x4
Vehicle: 02 jimny
Post Posted: Thu Oct 20, 2011 3:11 am
Pending on price. me
LIVING LIFE ON THE EDGE, TILL YA ROLL
Post Posted: Thu Oct 20, 2011 3:14 am
youll find CrMo grades in that size to be not a lot dearer than carbon steel due to availability
Vehicle: SJ80, SE416
Post Posted: Thu Oct 20, 2011 3:50 am
Any thoughts on Jimny/Coily models?
Vehicle: Samurai G16, DMax.
Post Posted: Thu Oct 20, 2011 3:55 am
I'll pick it up when I come to Melbourne just before Christmas. Steve.
92 Samurai G16
DMax
Post Posted: Thu Oct 20, 2011 4:10 am
I jsut asked the guru, 4140 is available in 30mm solid easy enough, for probably around $3.30 per kg carbon steel is around $2 so its not too much more considering the strength increase
Post Posted: Thu Oct 20, 2011 4:23 am
im keen as hell, can come down to pick it up as ill write the trip off on tax anyways :D
Post Posted: Thu Oct 20, 2011 4:26 am
So by those figures...
Density of 4140 (D) = 7810kg/m^3 (according to a google...)
Length of a draglink (L) = 1.4m (maybe I don't have one in front of me right now)
Radius of draglink (r) = 0.015m
mass = D x L x pi x r^2
mass = 7810 x 1.4 x pi x 0.015^2
mass = about 8kg ea
Not too bad. So most of the cost would be machining and the ends plus markup then.
Vehicle: SJ70 1993
Post Posted: Thu Oct 20, 2011 4:42 am
Noob question, advantages of this setup?
Lock, Drop and roll
Vehicle: SJ50 hardtop!
Sounds good. I might be interested down the track. Do you have any estimations on how much you'd idealy want to sell the setup for?
NT SJ50
Post Posted: Thu Oct 20, 2011 4:45 am
:helloo:
Post Posted: Thu Oct 20, 2011 4:48 am
So these are a replacement for the steering arms between the wheels and I assume from teh steering box as well
As well as being a bigger chunk of metal, its also likely to be a stronger grade which combined makes it harder to bend when you bash it on things
Post Posted: Thu Oct 20, 2011 4:50 am
Stock ones bend easily,
when you add bigger tyres, more offset,
power steering,
and do serious off road.
Weakened tie bar can also contribute to the death wobbles.
I found it very difficult to find straight ones at wreckers.
I have not voted, because I don't have a Sierra now.
Already strengthened Vit steering a bit.
Post Posted: Thu Oct 20, 2011 5:00 am
X2
Vehicle: SJ70 1993
Post Posted: Thu Oct 20, 2011 5:03 am
Ah ok cheers, i may be new to 4x4 but im i like splurging on my toys
Lock, Drop and roll
Post Posted: Thu Oct 20, 2011 5:49 am
ey lads, thanks for the response, obvious benefits are no probs with bent steering. I've bent mine twice now once hitting a tree stump and then would you believe just regular steering but the drivers side was loaded up and bent the tie rod on the rocks as I have massive forearms with no PS.
I really don't know what price they would be at this stage so I won't speculate until i do the costings and speak to my supplier.
Royce thanks for the tech info mate, that does help, maybe CrMo will be an option.
This is what i did on the weekend strong arm steering.
Post Posted: Thu Oct 20, 2011 8:20 am
yep id be interested for sure. My current HD setup is spare arms cable tied to my rollbar :)
Post Posted: Thu Oct 20, 2011 8:25 am
my engineer specified my draglink and tierod had to be a a certain alloy, i cant remember the grade exactly but he was very specific and it had to be solid bar not tube...
just FYI =)
Post Posted: Thu Oct 20, 2011 11:27 pm
thats interesting becasue heavy wall tube is actually stronger than solid...so i've heard.
THere is enough interest to pursue this so I will move forward and come back with more info as we go through the process.
Post Posted: Thu Oct 20, 2011 11:35 pm
The heavy wall tube has a bit more give than the solid, so it bends a little and goes back on the smaller knocks. From what i've been told, and seems to make sense.
Post Posted: Thu Oct 20, 2011 11:40 pm
Jimny to dank :helloo:
Post Posted: Thu Oct 20, 2011 11:42 pm
The Jimny wouldn't make it that far!
Post Posted: Thu Oct 20, 2011 11:56 pm
no way!
For a given total weight, tube will be stronger than solid (as it will be a greater OD) but for same OD solid will take more to bend
Post Posted: Fri Oct 21, 2011 12:46 am
I'd be interested depending on price and postage to WA
Post Posted: Fri Oct 21, 2011 1:05 am
Yep, id be interested too
Vehicle: Sierra
Post Posted: Fri Oct 21, 2011 1:17 am
no way!
If you have a solid tube and a thick walled tube both with the same OD then the thick walled tube will be stronger under torsion stress. This is assuming it is designed correctly. However these drag links are not failing due to torsional stress, so a solid tube will be stronger assuming the same OD.
Dale
Post Posted: Fri Oct 21, 2011 1:44 am
no way!
Dale
why arent all oem axles hollow then? would save them heaps to use alighter material
1 litre sierra had a solid driveshaft and it was tiny, if it was hollow it would twist first go
Post Posted: Fri Oct 21, 2011 2:15 am
or torsion bars? pretty certain mone are solid not hollow hahah
Post Posted: Fri Oct 21, 2011 2:41 am
no way!
agreed
Post Posted: Fri Oct 21, 2011 7:33 am
Research "gun drilling" axles.
Very small loss of torsional strength for a huge increase in flexibility, which might well reduce failure. Not the same issue as impact load on a steering rod though.
I am interested Dank, but I am interested on how you are going to deal with the drag link and weird double ball joint thingy.
Some hd rods with big greasable ball joints would be cool. Then we'd break steering boxes and knuckles :D
Users browsing this forum: No registered users and 143 guests
