It is currently Sat Nov 07, 2026 8:50 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Post Posted: Sat Oct 22, 2011 8:43 pm
Ok so like it says. I've got 6.5s and 31, how far out would my speedo be ?
2''lift 31's twin locked & 6.5s
Vehicle: MY2019 Jimny
Post Posted: Sat Oct 22, 2011 8:46 pm
Compare with a GPS?
I think from memory, about 15%?
Post Posted: Sat Oct 22, 2011 8:48 pm
the 6.5's wouldnt affect the speedo would it?
im curious on this too as i've got 31's and have 6.5s coming
Post Posted: Sat Oct 22, 2011 8:51 pm
Yeh it does cos ya speedo drive goes in to ya tcase and tha gears drop the gearing over the lot hi 4hi and Low
Post Posted: Sat Oct 22, 2011 8:54 pm
What diff ratios do you have?
Post Posted: Sat Oct 22, 2011 8:57 pm
in mine if ya doin 85 its 100...... 50 is 60.....
back in a built sierra!
Post Posted: Sat Oct 22, 2011 8:58 pm
Standed diffs
Post Posted: Sat Oct 22, 2011 8:59 pm
WT or NT?
Post Posted: Sat Oct 22, 2011 9:08 pm
Wt
Post Posted: Sat Oct 22, 2011 9:11 pm
nope. transfer gears don't affect speedo only diff gears affect speedo :wink:
Post Posted: Sat Oct 22, 2011 9:14 pm
How would that work the. With tha gears droping it done so low ??
Post Posted: Sat Oct 22, 2011 9:26 pm
The worm gear is still the same.
Post Posted: Sat Oct 22, 2011 9:28 pm
Oh ok so really it's just my tyres that have put it out
Post Posted: Sat Oct 22, 2011 9:32 pm
Yep, tyres and diff gears are what put it out.
Post Posted: Sat Oct 22, 2011 9:36 pm
x2 same as me, checked against GPS
apparently High range rduction is 11%
255 characters
Post Posted: Sat Oct 22, 2011 9:41 pm
bahhaaaa!
255 characters
Post Posted: Sat Oct 22, 2011 9:42 pm
the speedo cable is mounted to the transfer case not the diffs.
255 characters
Post Posted: Sat Oct 22, 2011 9:48 pm
have a look through here and you will see the difference in gear sizes between old and new. The high range is the big one. often you have to grind the transfer case back so the gears can actually fit in.
http://www.trail-gear.com/pdf/suzuk-tcase.pdf
255 characters
Post Posted: Sat Oct 22, 2011 9:50 pm
so, are you saying that i am wrong?
Post Posted: Sat Oct 22, 2011 9:51 pm
Cool thanks for all ya help guys
Post Posted: Sat Oct 22, 2011 9:59 pm
so which do ya believe?
trans gears change speedo or don't change speedo?
i am just curious.
Post Posted: Sat Oct 22, 2011 10:21 pm
i am just curious.
put ya car up on blocks.. remove the tail shaft then put it in gear and rev it... That will tell ya. :helloo:
255 characters
Post Posted: Sat Oct 22, 2011 10:22 pm
yep
255 characters
Post Posted: Sat Oct 22, 2011 11:42 pm
yep
Speedo cable is mounted to the tcase correct. It's driven off the tcase output shaft which is directly connected to the diffs. Thus any tcase reduction is "up stream" from where the speedo pickup is, hence reduction gears don't do a thing to the speedo
Lil Foot!
Post Posted: Sat Oct 22, 2011 11:53 pm
yep
how does it feel to be wrong? :lol:
Post Posted: Sun Oct 23, 2011 12:33 am
yep
ahhh but i am not wrong :wink:
Post Posted: Sun Oct 23, 2011 12:36 am
tell me how the output shafts speed is made different to road speed. :helloo:
or to put it another way what is inbetween the tyre contact patch and the transfer output shaft. :wink:
Post Posted: Sun Oct 23, 2011 12:46 am
Diff gears and that's it................
Lil Foot!
Post Posted: Sun Oct 23, 2011 1:19 am
Shep is right , tyres and diff ratios are the only way to affect speedo , on a sierra transfer , put it in gear with tail shaft of and rev , this is only going to show the gearbox and transfer ratio verse speedo indication.
The speedo is gear driven on a sierra , so the only way to alter this is by changing the tyre diameter or changing diff gearing , any other way is wrong , wrong , wrong , Cheers Paul.
Post Posted: Sun Oct 23, 2011 1:50 am
Just to confirm from the outside Shep is on the money. it is pretty much common knowledge here that the transfer gears do not affect the speedo reading, only tires and diffs will.
The speedo function is based on the RPM of the transfer output. Anything past the transfer case will throw it out, anything in front of the transfer will not.
Users browsing this forum: No registered users and 115 guests
