It is currently Sat Nov 07, 2026 8:45 pm
Post Posted: Sat Oct 22, 2011 10:03 pm
hi guys does anyone know a reason why i keep snapping my passenger side transfer mount ?
i put all new mounts in yesterday and after 30 minutes of wheeling i snapped it again .
i have reduction gears but i dont wheel hard.
gearbox mount is fine and engine mounts are fine .
cheers guys
Post Posted: Sat Oct 22, 2011 10:10 pm
what reduction are you running
Vehicle: SUZZI
Post Posted: Sat Oct 22, 2011 10:36 pm
series 4's wich 6.5 rockhopper
lux diffs,twin locked,crawler gears,37s,etc
Post Posted: Sat Oct 22, 2011 10:39 pm
It's one of those things mate. Look into a roctoy incorporating a transfer cradle, helps to distribute the stress a bit better in the mounts. If not, maybe look into a just cruising transfer lift, definately better and stronger than original mounts 8)
Vehicle: 2018 DMAX
Post Posted: Sat Oct 22, 2011 10:41 pm
4.9s are enough to kill mounts. You could try replace them with something stronger, but this will move the weak point somewhere else on the transfer case.. My case uses body lift pucks with some HT bolts through them.
Post Posted: Sat Oct 22, 2011 10:44 pm
are you sure ? i thought it was stage 3 ?
Post Posted: Sat Oct 22, 2011 10:46 pm
the problem is i cant lift my t case as i have a long arm kit installed and the main bar for my A frame sits 5mm above the rear flange on the t case
Vehicle: SUZZI
Post Posted: Sat Oct 22, 2011 10:53 pm
Your old cage looks good on my zook now :D
d ill call ya soon mate
Post Posted: Sat Oct 22, 2011 11:00 pm
thanks guys
Vehicle: 2018 DMAX
Post Posted: Sat Oct 22, 2011 11:02 pm
Armsup Cool, have to put some pics up!
dexter, just wrap a ratchet strap around the mount when you go wheeling :lol:
Post Posted: Sat Oct 22, 2011 11:18 pm
get a standard height just cruisin mount kit.
Post Posted: Sun Oct 23, 2011 12:34 am
Try using genuine transfer bushes instead of aftermarket.
Post Posted: Sun Oct 23, 2011 12:42 am
X2 :helloo:
Vehicle: Sierra
Post Posted: Sun Oct 23, 2011 4:17 am
maybe this is your problem? Stock mounts can stretch a lot under shock load.
I run a polaris engine mount (can supply part# if you like). They are around $30 each, are rubber and still stretch like stock ones but have a higher tearing point. I run 6.5's with no ther reduction and 33" Bias TSL's. So far no problems including a couple of 1st and 2nd low clutch dumps, but generally I am pretty easy on it.
Post Posted: Sun Oct 23, 2011 4:25 am
I've snapped my engine mount, bent my long mount on the transfer and torn a rubber mount.
with 4.1's. Brace the shit out of it haha.
Post Posted: Sun Oct 23, 2011 4:36 am
When you replace your t-case bushings make sure you check your transmission ad engine mounts too. It seems to me one will take out the other and vice versa. I was loosing mounts like crazy until I found my motor and trans mounts were bad too and replaced them, so far no more broken mounts.
Post Posted: Sun Oct 23, 2011 4:47 am
Try these MAZDA 323 1977 - 1978, RWD, 4CYL 1.3L TC engine mounts part number mt8135 cheers
Post Posted: Sun Oct 23, 2011 4:49 am
I run soild mounts
maybe run a lhs solid. ie bolt right through whatever you want to use to space the transfer off the mount
Post Posted: Sun Oct 23, 2011 5:27 am
Have a look here mate.. :)
http://auszookers.com/index.php?name=Fo ... ic&t=21919
F&R ARB air lockers, lux diffs, 4 link coil rear,
Post Posted: Sun Oct 23, 2011 5:35 am
thanks guys very helpful :) i look in to everything and see how it goes
cheers
Users browsing this forum: No registered users and 152 guests
