It is currently Tue Nov 10, 2026 6:25 am
Post Posted: Tue Nov 01, 2011 8:53 am
Does anyone make stronger aftermarket CV's for the 98-05 GV? Im guessing it gonna be a regular thing ill break now that its Twin locked.
Post Posted: Tue Nov 01, 2011 9:28 am
Yeeeep!
And you're axels...
If your not breaking shit, try harder!!!
Post Posted: Tue Nov 01, 2011 9:38 am
Was twin air locked in my 2000 GV for a LONGGGGGGGGG time and never did a CV.
I don't know any other company that make stronger CV's.
Post Posted: Tue Nov 01, 2011 9:49 am
Hit Mr Joe Blow up for some
Post Posted: Tue Nov 01, 2011 5:30 pm
Ur only choice is custom at the moment as lux ones would be to short in a gv I would think as they fit 1.6 vits
Maybe 100 series could be made to fit
Porche cv would be the go as you can rebuild them and there designed to run on bigger angle with huge amounts of power
Post Posted: Tue Nov 01, 2011 7:04 pm
This is interesting.
with out pulling it out and looking what is the weak point that breaks the most with a CV? Would it be easier to make that part stronger or what about getting some CV's cryo frozen...thats ment to toughen things up alot......
Post Posted: Tue Nov 01, 2011 8:28 pm
A lot of the big power tube buggies running bike engines use the Porche 930 CV's as they take ridiculous power as GBW said.
Post Posted: Tue Nov 01, 2011 8:36 pm
I don't think heat treating will make much difference
The problem is that we keep looking for down travel . At full extention the struts are near the limit add some hard lock and there almost binding . Big tires and right foot and bang it's gone .adjusting steering stops helps but at the end of the day there operating outside of wat there designed to do.
U need something that is designed to run on bigger angle and made for more power
Post Posted: Tue Nov 01, 2011 8:41 pm
A guy on Zulu world is looking a building 12" travel kit for vits
He's going to use the 930 cv and a custom strut made from a 2" remote res shock where the body becomes the shaft
It will be about 2.5" wider a side
Post Posted: Tue Nov 01, 2011 10:11 pm
Afew years ago a mate had a set of axles made up with 2 unis and a slip axle inbetween.
He kept busting cvs in his civic
Post Posted: Tue Nov 01, 2011 11:48 pm
This setup has me interested........would be an easy tracktracl side fix if they were bolt in unis.
After some ringing around i found a place that say they can make stronger unis and shafts. He needs your shafts and will rebuild them with stronger Uni's and longer shafts for $250 each side.
tempting but might ask about some more.....uni shafts sound the go.
Post Posted: Wed Nov 02, 2011 12:00 am
Would a uni run on a high enough angle
A tompson cupling would be the go
Post Posted: Wed Nov 02, 2011 1:15 am
Just spoke to Suzuki about a genuine CV. The CV joint on its own is over $500 and a complete shaft with CV's is over $1000 +gst. 8O 8O
Think i might just stock up on some 2nd hand ones.
who has some ????
Post Posted: Wed Nov 02, 2011 1:20 am
All the dana's use them intead of cv's on solid axles, but, The uni may bind up for ifs when steering and flexing.
It will be ok for a civic, as they dont move much.
Why are you blowing cv's? Is the diff dropped to suit?
Thanks for mentioning the thompson coupling. Never seen them before. :D
Post Posted: Wed Nov 02, 2011 1:26 am
80mm lift, diff drop bkts, and a locked diffs may be why. but then it might just have something to do with where and how i drive it :crazy:
Users browsing this forum: Google [Bot] and 381 guests
