It is currently Tue Aug 04, 2026 11:23 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Post Posted: Sun Nov 06, 2011 6:47 am
My Sierra feels like it's missing but could it be running on 3 or less cylinders? Once it's going it's ok but has no balls should I bite the bullet and do a rebuild? Or sus it out
Post Posted: Sun Nov 06, 2011 6:53 am
start the car and pull the lead of plug 1
then 2
then 3
then 4
when u pull one of and it dont make a difference to the way it idels you will know its that cylinder. if all of them make a difference then its running on 4 cylinders
THINKING BEFORE POSTING!!!
Post Posted: Sun Nov 06, 2011 7:00 am
And if it's that rebuild?? Cheers for that I'm doing it now
Post Posted: Sun Nov 06, 2011 7:15 am
Still dos it really confused on what it is could it be the head gasket? No water in oil or vise versa but it is oily around the manifold pulling it off to have a look
Post Posted: Sun Nov 06, 2011 7:21 am
pull the air cleaner off and see if it helps
if not
swap two of the spark plug leads and start it. (put it back together PROPERLY first
btw its gona go BANG when u do this, but it should temporaroly clean the carby.
put the leads back on the right way and see if it works.
just thinking of it. u havent pulled all the leads of and put them back in the wrong order at any point have you. signs for a rebuil gradualy get worse over a matter of months. normaly.
Post Posted: Sun Nov 06, 2011 7:25 am
That's the oil on the exsust manifold
Post Posted: Sun Nov 06, 2011 7:30 am
im guessing an exaust valve on the second cylinder. but everything i know about engines comes from bikes mainly two strokes so exaust valves i cant help you with, is it burning oil?
how many kms has it done?
Post Posted: Sun Nov 06, 2011 7:36 am
It burns a fair whack of oil it's got 280 290 ks
Post Posted: Sun Nov 06, 2011 7:39 am
smell your oil does it smell like fuel? sorta
Post Posted: Sun Nov 06, 2011 7:41 am
Smells like fuel almost like 2stroke lol
And it gets blow by so oil in the airfilter
Post Posted: Sun Nov 06, 2011 7:45 am
well ur in need of some new rings for starters. and i would check the exaust valves while ur at it.
dont ask me how coz idk, two stroke dirt bikes dont em them
Post Posted: Sun Nov 06, 2011 7:46 am
plugs are prob oil fouled. pull the plugs and clean them or replace them. Will be a temp fix but you will have to rebuild it sooner than later.......start looking for a cheap low km swift engine.
Post Posted: Sun Nov 06, 2011 7:49 am
The plugs are about 5 k old already fouled that's gay what year swift engine?? Or any I couldve got one of my mate for 450 with injection comp and all spewing
Post Posted: Sun Nov 06, 2011 7:52 am
prety sure its 89-96 swift or barina.
Replacing the plugs won't fix it if something is wrong elsewhere. Clean them and go for a drive then have a look first.
Post Posted: Sun Nov 06, 2011 8:01 am
I'm biting the bullet and looking for a motor got to be done
Post Posted: Sun Nov 06, 2011 8:18 am
this is the basic checks i do when an engine isnt running right
P= petrol, is the engine getting quantaty and quality needed. check, fuel filters lines etc, under petrol comes air aswell, this means does the car get the right fuel air mixture, run it with the airfilter off in a ust free environment and see if it helps. then do the switchy plug lead trick
O= oil is it getting necissary lube, in your case probably not but it will do for now
W=water is its cooling working right. is it using water. if so then ur head gasket is probs farked
E= electrics, its a sierra so there is no ecu to worry about. check the output of the coil (dont think u need to in this case) then pull the dizzy cap of an wrigle gently the rotor SIDE TO SIDE and up and down DONT TWIST IT, is there much play in it (fairly good chance this may be the probs) note when u r doing this dont pull the leads of it.
R= rubber is for getting the power to the floor. checks include, brakes, tyres drivetrain etc. ur having problems getting power not getting it to the floor so dont worry about this.
have u tried doing the lead switch, to clean the carby,
and go check the dizzy, like i said
if the dizzy is fine pull your plugs one by one (not the leads, the plugs) plug
the plug to the lead and holding the rubber bit with your hand and the tip of the plug to the engine block, get some one to turn the car over. if there is no spark, replace the plug (with a new one) and try again, if still no go, you need to check the out put of the coil, if thats all sweet, put a new set of leads on it. if your getting spark then u can rule out electrics.
all that leaves if fuel air mixture (carby) and valving problems/ serious engine problems. check for water in the oil. (white gum on the filler cap) and we know the rings are fruked so not much point checken the oil other than it being there. either way if u reach this point your gona need to go to a mechanic
Post Posted: Sun Nov 06, 2011 8:21 am
HOLD UP DONT DO THAT UNTIL I HAVE FIXED IT AND ASSURE ME U GOT THIS
Post Posted: Sun Nov 06, 2011 8:23 am
Daves sierra burns quite a bit of oil and also blows it out the exhaust both on start up and when under load......and with that many kms on the original motor id say its time for a rebuild/replacement. Any fix to a motor with that many kms is only gonna be tempoary
Post Posted: Sun Nov 06, 2011 9:07 am
I'm goin to rebuild the motor that's in it later on with some goodies ie cam flat top pistons a little more power and no need for a engineers cert would
Love to the 1.6 but money says no when I say yes hahaha I'll buy a cheap motor with low k for now it's my daily so it can't be off the road for more then a weekend witch sucks plus trying to get my
Other car on the road and when that happens I can take it off the road and stuff around with it more then a weekend but thanks for the help I'll try doing some tests to get her running a little better after work tomorrow if I make there and home HAHAHAHA thanks for the help guys it's very much appreciated
Post Posted: Sun Nov 06, 2011 9:18 am
for starters try a thicker oil with a stabliser in it. should make it burn less. and keep cleaning the plugs.
Post Posted: Sun Nov 06, 2011 9:33 am
I'm running a thick oil it's a nulon can't remember how thick but it's one of the thickest hopefully have a engine this weekend in it and rebuild my carb I'll get my mate to have a look and see what he can do to get more time if I don't find one
Post Posted: Sun Nov 06, 2011 10:34 am
Also is the barina g13b the same engine as the Suzuki??
Post Posted: Sun Nov 06, 2011 11:32 am
Churrrr.
Post Posted: Sun Nov 06, 2011 11:52 am
same car!
Post Posted: Sun Nov 06, 2011 6:30 pm
Pretty much the same motor but a few minor differences. You will have to swap the sumps, cam and manifolds over. possibly the water pump and pulleys too if you wanna keep a fixed sierra fan. nothing terribly hard just time consuming.
get the motor and buy a VRS gasket kit. that way you get all the gaskets you need bar the sump gasket.
Post Posted: Sun Nov 06, 2011 7:04 pm
Worse comes to worse I'll do that thanks
Post Posted: Mon Nov 07, 2011 3:42 am
Another reason it may have been sluggish is when i met you was there were 4 largish people driving around in it....... :helloo: :helloo: :helloo: :helloo:
Post Posted: Mon Nov 07, 2011 4:18 am
Yer that could be a slight problem hahaha I pulled off the muddies to get it to run a little better and then drove to Hamilton and then in the city it just started and no where has a g13b engine so I think I'm fucked on what to do might rebuild it
Post Posted: Mon Nov 07, 2011 7:41 am
what about this?
http://www.ebay.com.au/itm/Damaged-1994 ... 2569082f4f
just have to check its the correct motor.
Users browsing this forum: No registered users and 311 guests
