| Author |
Message |
twitchy
Joined: Fri Jul 25, 2008 11:30 pm Posts: 1086 Location: Lightning Ridge
Vehicle: 1999 Jimny
 Posted: Sun Nov 13, 2011 1:33 am |
Looking at buying the missus an XL7, anything I should know good or bad on these??? 2001 model.
Oh & G'Day by the way, been a while..
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Sun Nov 13, 2011 1:55 am |
Basically the same as a GV except they are longer and have a different rear diff.
Check for timing chain rattle on cold start up.
Check gearbox cross member for damage, good indicator if its been offroad.
Look inside the rear boot wet cell for rust.
Manuals suffer form a heavy and short clutch pedal.
Look for signs that the c/case has been apart. there was a factory recall on a gear inside early models. If the case has been apart it most likely has been replaced.
Check for oil leaks. front crank case seals leak.
Make sure the deflectors are still intact inside the headlights
Front seats wear out the side cushions closest to the door,
And most will require new suspension bushes at that age.
_________________ B4T
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sun Nov 13, 2011 2:12 am |
Still got the Rover Pete? Welcome back
MacDaddy
Joined: Thu Mar 26, 2009 10:30 pm Posts: 10453 Location: Perth, Australia
Vehicle: Jeep
 Posted: Sun Nov 13, 2011 2:22 am |
Is there a reason you chose an XL7 and not a GV ?... the XL7 has a 2.7L V6, and they can be very thirsty, the mechanic at Suzistore has an XL7, and he says he is lucky to get 400kms from a tank... also, it may be a bit hard for your missus to park in a shopping centre, due to its extra length... imo, maybe it would be better to get a GV...
twitchy
Vehicle: 1999 Jimny
 Posted: Sun Nov 13, 2011 2:43 am |
Still have the rover
7 seats, was one of the reasons for choice.
Motor was quiet as a mouse.
Joe
Joined: Sat Jul 04, 2009 11:30 pm Posts: 49041 Location: Rockingham W.A
 Posted: Sun Nov 13, 2011 4:16 am |
MacBear wrote: Is there a reason you chose an XL7 and not a GV ?... the XL7 has a 2.7L V6, and they can be very thirsty, the mechanic at Suzistore has an XL7, and he says he is lucky to get 400kms from a tank... also, it may be a bit hard for your missus to park in a shopping centre, due to its extra length... imo, maybe it would be better to get a GV...
Yeah but look at how he drives it
_________________ Joe likes boobs ( . )( . ) ( ° )( ° )
tombutt
Joined: Sat Jul 19, 2008 11:30 pm Posts: 1917 Location: brisbane
 Posted: Sun Nov 13, 2011 5:59 am |
400km to a tank sounds amazing to me im lucky to get 350 to a tank from a tiny 2L
MacDaddy
Vehicle: Jeep
 Posted: Sun Nov 13, 2011 6:08 am |
tombutt wrote: 400km to a tank sounds amazing to me im lucky to get 350 to a tank from a tiny 2L
Compared to the 2.5L V6 in the GV its very thirsty... i can get 450kms min being a lead foot, and nearly 500kms taking it easy... and some have got nearly 600kms on long h'way trips...
twitchy
Vehicle: 1999 Jimny
 Posted: Sun Nov 13, 2011 6:20 am |
MacDaddy
Vehicle: Jeep
 Posted: Sun Nov 13, 2011 6:46 am |
twitchy wrote: Tank size???????
66Litre in both the XL7 and GV...
tombutt
 Posted: Sun Nov 13, 2011 6:48 am |
MacBear wrote: tombutt wrote: 400km to a tank sounds amazing to me im lucky to get 350 to a tank from a tiny 2L Compared to the 2.5L V6 in the GV its very thirsty... i can get 450kms min being a lead foot, and nearly 500kms taking it easy... and some have got nearly 600kms on long h'way trips...
i think mine comes down to the extra weight/drag of everything plus the larger tyres and my spirited driving
twitchy
Vehicle: 1999 Jimny
 Posted: Sun Nov 13, 2011 7:40 am |
The minister for finance & war currently drives a series one Discovery, I'm sure she will manage.... oh she said to tell you some about sex & travel....
BlueSuzy
 Posted: Sun Nov 13, 2011 7:43 am |
MacDaddy
Vehicle: Jeep
 Posted: Sun Nov 13, 2011 2:05 pm |
twitchy wrote: MacBear wrote: Is there a reason you chose an XL7 and not a GV ?... the XL7 has a 2.7L V6, and they can be very thirsty, the mechanic at Suzistore has an XL7, and he says he is lucky to get 400kms from a tank... also, it may be a bit hard for your missus to park in a shopping centre, due to its extra length... imo, maybe it would be better to get a GV...  The minister for finance & war currently drives a series one Discovery, I'm sure she will manage.... oh she said to tell you some about sex & travel....
Haha... ok fair enough...  yes well there will be plenty of room in the XL7 for that...
[E-Z]
Joined: Mon Oct 25, 2010 7:32 am Posts: 131 Location: sunshine coast QLD
 Posted: Sun Dec 25, 2011 9:19 am |
maybe too late, but i get 550ks a tank easy XL7 with a busted ass o2 sensor, used to get 600+
