It is currently Wed Aug 05, 2026 1:51 am
Post Posted: Wed Nov 16, 2011 11:40 pm
hey guys just wondering if nt and wt calibers are the same or if anyone has a good way to remove a piston from the caliber.
Post Posted: Wed Nov 16, 2011 11:46 pm
yep, pretty sure they are, and if not the differences are so minute it makes no difference
Post Posted: Wed Nov 16, 2011 11:57 pm
to remove piston
stick a rag in front of the piston, wadded up so it cant fly out and get damaged
stick an air blower in the brake line connection ans slowly blow it out
or jsut pump the pedal with the caliper off, fluid will go everywhere
Post Posted: Thu Nov 17, 2011 12:20 am
have already tried blowing air down it didn't even budge and back brakes are off so no pressure in the lines
Post Posted: Thu Nov 17, 2011 12:22 am
Push it in a little first then Blow harder
Post Posted: Thu Nov 17, 2011 12:53 am
hook it back into the brake lines and push the brakes. The pressure will pop out the piston :D But as Royce says, fluid will go everywhere!
Users browsing this forum: Google [Bot] and 536 guests
